DC Servo DIY Kit for DCCancellation - diyAudio
Old 19th April 2015, 11:20 PM   #1
Default DC Servo DIY Kit for DCCancellation
Hello friends. I would like your opinion on this correction circuit dc offset.
Worth the installation in Rotel RA-970BX. Thanks to you I have corrected an offset of + 70 to -68 mV. But I still -20mV in both channels.
* From already thank you and excuse the insistence. With you I am learning not to make mistakes and correct defects in my amp. Greetings.
2X DC Servo DIY Kit for DC Offset Cancellation Mono of Power Amplifier | eBay
Old 20th April 2015, 01:02 AM   #2
nigelwright7557's Avatar
With 20mV offset there is no need for a DC cancellation.
20mV is not going to move the speaker much.
PCBCAD51 pcb design software. http://murtonpikesystems.azurewebsites.net/
Old 20th April 2015, 01:48 AM   #3
Thank you. Is that as the Rotel is not intended to calibrate the dc offset, I would take it to zero mV. I had understood that it is desirable to less than 15 mV. But if you say no harm -20 mV, so I'll leave. Thanks again.
Old 20th April 2015, 01:57 AM   #4
I would accept quite a bit more than 20mV.
The offset can wander a bit as the amp warms up.
I would check that and decide from there if you need dc cancellation.
Old 20th April 2015, 02:02 AM   #5
It is so. Lights when the amplifier, being at room temperature, the offset is -24 mV. After arriving 30 minutes to stabilize at - 19 L and - 20 mV in R.
Old 20th April 2015, 02:04 AM   #6
That's sounds good.
Old 20th April 2015, 02:41 AM   #7
Well, thank you.
CSH9 - Simple DC coupled power amp with pre-amp, volume control and DC servo Ranchu32 Solid State 1 13th February 2015 08:31 AM
To use DC servo or not? jaycee Solid State 42 8th December 2014 08:19 AM
DC servo audiohead Solid State 13 22nd November 2011 11:32 PM
DC blocking cap in feedback path or DC servo? roender Solid State 27 19th September 2007 09:40 AM
DC servo Bensen Solid State 0 23rd May 2003 11:34 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
