Opinion about PCB
I'm learning drawing PCB boards. For my first board I chose Jlh1969. Can somebody give my any opinion...will it do it's job? My board is in the attachment (last file is bottom and silk on top). I have also attached silk and bottom separately.
Sorry if I made some grammar mistakes🙂.
I have used expresspcb. But is it so bad😉? Here is my schematic http://www.startfetch.com/jlh/jlh-1969-amplifier.gif I will use it with 8 ohm (I will use big cap's for ex. nichicons so for a place for big caps I will be grateful) also I would like to use 2sc5200 as output transistors and simple PSU integrated with amp board (just normal diode bridge and 2x10000uf caps)
Thanks in advance Oskar.
Someting like this.....🙂 Program it's Sprint Layout6.0
Regards, Alex
  • 148 JHL 1969 ALL.pdf
  • 148 JHL 1969 BOTTOM.pdf
  • 148 JHL 1969 SILK.pdf
