Strategy to track down a short - diyAudio
Old 15th April 2015, 01:53 AM   #1
Bcjm is offline Bcjm  United States
Default Strategy to track down a short
My integrated amp has a short that causes the fuse to blow. I have replaced the output transistors on one channel because they were shorted. The driver transistor seems fine so I did not replace. The light bulb in DBT were bright when I turned the amp on so the root cause is there there somewhere. When I disconnected the driver from the bad channel, the light bulb in DBT was dim. That makes me believe the other channel is working.
I am thinking I can measure and compare the voltage or ohm of two channels at different points to find out the defective component. But since there is a short the readings may not be reliable. Any other suggestions?
Thanks. Bob
Old 15th April 2015, 05:54 AM   #2
You have to go towards the frontend, as in some circuits, the input transistors can also blow as a result.
Gajanan Phadte
Old 15th April 2015, 05:59 AM   #3
Cortez is offline Cortez  Hungary
Cortez's Avatar
As the first step measure all of your resistors and semis (in diode mode with your DMM) to check for bigger fails.
Most of the cases this is enough to locate the error.
Old 15th April 2015, 02:21 PM   #4
Can a shorted input transistor cause the fuse to blow without any input signal?
Old 15th April 2015, 03:54 PM   #5
Cortez's Avatar
I would say yes.
Old 15th April 2015, 08:30 PM   #6
east electronics's Avatar
I would say no but problems like the bias circuit and a shorted Vbe multiplier could drive the output to full bias so yet again the bulb will be bright but the cause will be laying elsewhere ....
So the title of your post might be wrong , your method seems to be also wrong measuring a few things like bias, proper rail voltage, state brand and model and help is on the way ...
remember that a common failure around bipolar transistors is that may measure OK outside the circuit but fail under voltage
Kind regards
Sakis
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 15th April 2015, 09:02 PM   #7
My bias voltage does show significant difference between two channels. What do you think I should check?
Old 15th April 2015, 09:04 PM   #8
tomchr is offline tomchr  United States
tomchr's Avatar
A common cause of blown fuses is a shorted supply cap...
If you can operate the amp with the short circuit error without blowing fuses (so run it at low voltage or through a light bulb tester) you may be able to find the short by measuring between various points on the supply and ground lines. Basically, you're looking for a large voltage drop across any part of the ground or supply line impedance. That may give you some clues.
A shorted Vbe multiplier would drive the output bias to 0 A. That would work rather well for protecting the amp. An open Vbe multiplier would crowbar the output stage.
Tom
Modulus-86: Composite amp achieving 0.000067 % THD. Damn Good 300B, Novar Spud, 21st Century Maida Reg., Filament Reg., etc.
Neurochrome : : Audio - http://www.neurochrome.com - Engineering : : Done : : Right
Old 15th April 2015, 09:42 PM   #9
shorted vbe with a blown resistor next to it or a shorted driver at base is more likely but my suggestion was a pointer not the exact description ...
shorted capacitor ...???/ never found one and today we are just a bit over 1000 audio devices per year at east electronics ..shorted bridge i would say far more common ....
Old 15th April 2015, 09:49 PM   #10
I have adjusted the good side bias to 15 mv based on the service manual.
The bad side stayed in 44 mv and the adjustment pot does not change the reading.
Could someone tell me more about the Mesa Boogie Strategy 400? JZatopa Tubes / Valves 14 9th February 2014 08:32 AM
MESA STRATEGY BIAS MOD blackarab Instruments and Amps 7 19th November 2012 05:37 PM
MESA STRATEGY 400 blackarab Tubes / Valves 7 15th November 2012 02:14 PM
Best strategy to convert Aleph 3 to monoblock Sony Pass Labs 6 23rd April 2012 06:51 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
