Hi I fixed a Dynaco st-80 amp, and on one channel (one I fixed) when you put a load on the output the neg half of the waveform oscillates. the system has all new transistors, new caps for output zobel(c8), and bypassed the speaker out cap(c7). if you scope at the the transistor out it is really ringing, at the speaker out (after the cap\coil (c7\L1) it is subdued. When I added a mylar bypass on c4 it rang all over the sine wave so I took it out.
Your thoughts are appreciated. thanks
john
john
That would make it not work by itself ... why? It's not a DC
coupled amp ?
OS
That would make it not work by itself ... why? It's not a DC coupled amp?
I think that he means that he added a small cap in parallel.
Why ?
OS
the cap worked 12pf on q4
Hi Nigelwright7557, spot on that work , clean signal now. I would have thought the Q3 would need it, glad I got your help
Hi Art M, there is a guy from Jersey on Ebay selling kits for most Dynaco kits.
I had run out of fixes so I did a shot gun try, turned out it was a broken lead on the 5v zener . then the output oscillated on load, so I came here. the best people are here.
thanks everyone.
john
thanks everyone.
john
- suggestions for oscillation on neg half of output
