Krell KSA 300s Integrated circuit - diyAudio
Old 31st March 2015, 01:51 AM   #1
xmates is offline xmates  Viet Nam
Default Krell KSA 300s Integrated circuit
Hi everyone,
I'm from Vietnam. My Krell KSA 300s is now running with very low level at one channel. So I get a Technician and he found that the Integrated circuit( I don't know whether this named in English is correct) at Q33 position on driver board is dead. It is marked with D9517- 2N5564
I checked with Krell and they give me the unbelievable price: $65 for each.
Does some one have this? Or where I can buy the exact one to replace because my techician said this one is not a normal as the other ( he checked and found st strange- this is a double, one long one short,or st like that, my god , I don't know what it means).
I find the 2n5564 on alibaba but they don't have the mark D9517, just 2N5564. This pos is the start of signal so I think the bad one can cause terrible at the ending output.
Tks n Brgds!
Old 31st March 2015, 02:21 AM   #2
Linear Systems says their LSK389C is a replacement, see here. This also means that a well matched pair of high IDSS 2SK170 BL's or 2SK170V will work as well.
Because the 170's are still somewhat available at a reasonable price you might want to consider replacing the 2N5564 in the other channel as well.
KC
Old 31st March 2015, 02:47 AM   #3
Tks Mr Chamberman, But If I replace this, any problem with sounding? Should I take a pair and remove the one on other chanel for the same sounding at both?
Help plS!
Old 31st March 2015, 03:00 AM   #4
Sorry wrong link in the previous post. Here is the cross ref sheet.
KC
Old 31st March 2015, 04:53 AM   #5
D9517- 2N5564, what does D9517 meaning? Can I do without this mark? Sorry I don't have any electronic knowledge, the technician is also not sure about D9517.
Mny tks!
Old 31st March 2015, 11:04 AM   #6
Mny tks!
D9517 = Manufacturer Date/Batch coding. Probably 17th week of 1995 if I had to guess.
KC
Old 31st March 2015, 11:18 AM   #7
Help plS!
Yes I would definitely change the input Jfet pair in the functioning channel as well. Not only to maintain symmetry between the channels and eliminate any chance of sound differences between them due to the new Jfet's, but also for reliability. If the 2N5564 has failed in one channel then it may very well be on its last leg in the second channel.
DIYAUDIO user Alweit sells matched quads of genuine Toshiba 2SK170BL's on Ebay under the same user name. Alweit's Jfet's are well matched and not expensive. Beware, there are a lot of fake Jfet's out there. If you purchase them from China off of Ebay you WILL RECEIVE FAKES. I would contact Alweit and ask him if he has a matched quad with an Idss of > 10ma that you can purchase.
KC
Old 31st March 2015, 12:20 PM   #8
Ketje is offline Ketje  Belgium
Ketje's Avatar
You could also consider using Toshiba's 2SK389.
Different envelope, somewhat more difficult to replace .
Mona
Old 31st March 2015, 12:35 PM   #9
Mona
I wouldn't do that. The 2SK389 only has a total Pd rating of 400mw, the 2n5564 is rated for 650mw. If the reason for the failure was due to running a rather high Pd then the 2sk389 will fail quickly. The 2sk170 pair will have a total Pd of 800mw and be a more reliable choice.
KC
Old 31st March 2015, 02:22 PM   #10
Ketje's Avatar
The photo shows a TO-18 envelope so 650mW
It's a differential input stage, Pd is not an issue here.There is no provision made to adjust a possible inbalance, two 170's is not a good idea unless you modify the circuit an glue them together.
Mona
krell ksa 5 Zen Mod Solid State 82 6th November 2016 11:53 PM
Krell KSA-300S will not turn on fcel Solid State 54 26th March 2015 03:01 PM
krell ksa 300s right channel dead maybe transistor problem?? yipyip55 Solid State 25 19th July 2012 07:21 PM
Krell KSA-300S cliks off rextech Solid State 0 15th July 2011 11:31 AM
Krell KSA-300S Chassis Restoration john65b Solid State 5 7th June 2010 03:00 PM
Copyright 1999-2017 diyAudio
