Denon SA-3350 amplifier weird distortion
Old 24th March 2015, 08:06 PM   #1
partyface86 is offline partyface86  Romania
Default Denon SA-3350 amplifier weird distortion
Hello fellow audio enthusiasts!
I have a little problem with a vintage Denon SA-3350 amplifier. Both STK078 ICs have been replaced with STK086 as these were the only ones I could find that were decent.
However now I have some weird distortion (could be crossover distortion, i`m not sure as I don`t have a scope), at very low volume it sounds OK, but as I raise the volume it sounds kind of crackly, and starts to sound somewhat normal again at high volume.
The STK078 is 25W and the STK086 is 70W but the circut is exactly the same and they are perfectly pin compatible, however the STK086 needs a recomended voltage of 42V and max 55V. The amps power supply has 32V. Could this be the issue?
Note: the DC offset is also qiet high, at about 80mV
Old 24th March 2015, 08:43 PM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
This will be your answer;
Hybrid-IC STK078 ; Power Audio Amp | eBay
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 24th March 2015, 08:47 PM   #3
Originally Posted by JonSnell Electronic View Post
Thanks, but I never bought and probably never will buy from ebay.
Old 25th March 2015, 08:10 AM   #4
djk is offline djk
R.I.P
djk's Avatar
" as I raise the volume it sounds kind of crackly"
While you are turning the control?
Is it just a dirty control?
Candidates for the Darwin Award should not read this author.
Old 25th March 2015, 08:26 AM   #5
No. The controls are fine, I`ve cleaned them with deoxit.
Denon SA-3350 amplifier weird distortionHide this!Advertise here!
Weird fuses in Pioneer SA-510 Cr3ator Parts 12 21st May 2017 06:39 PM
denon avr-1906 thump problem (weird) kylecattee Solid State 0 14th May 2012 06:08 PM
help:schematics for a Denon SA-3350 int amp georgepogi69 Solid State 3 12th February 2012 12:25 PM
Help with some weird distortion Binaural Analogue Source 16 17th June 2009 06:07 AM
