Class AB amp with booster capacitor supply - diyAudio
Old 24th March 2015, 10:18 AM   #1
Default Class AB amp with booster capacitor supply
I have good-for-audio filter capacitors and many general quality capacitors. The audio-good will be used as main filters and other will be connected as boosters when the amp demands.
I listen to music at a moderate level which does not need big microfarads.
What happens if I use these as shown in the schematic.
Gajanan Phadte
Old 24th March 2015, 10:41 AM   #2
Your supply voltage droops when demand increases.
regards Andrew T.
Old 24th March 2015, 10:58 AM   #3
AJT is offline AJT  Philippines
AJT's Avatar
first time i have seen such a scheme, and why not?
your reserve will be on standby most of the time, or maybe not...
the best advertisement for a good audio design is the number of diy'ers wanting to build it after all the years....never the say so of so called gurus....
Old 24th March 2015, 11:46 AM   #4
It happens in any case.
Gajanan Phadte
Old 24th March 2015, 12:01 PM   #5
Mooly's Avatar
I don't think it would work as you intend tbh. The two supplies are essentially in parallel, the diode gating doesn't really isolate them. As you draw more current you just pull both rails down together.
Installing and using LTspice. From beginner to advanced.
Old 24th March 2015, 12:03 PM   #6
Mark Whitney's Avatar
Try simulating the circuit. I am convinced it will give you some interesting voltage and current wave forms.
Depending on the amount of capacitance of each part, there will need to be a enough current demand to drop the voltage by more than the forward voltage of the diodes.
The same with the charging currents to the capacitors, with the main capacitor bank starting to charge first.
Regards Mark.
Old 24th March 2015, 01:29 PM   #7
danielwritesbac's Avatar
Reverb? Echos?
Old 24th March 2015, 05:51 PM   #8
CBS240 is offline CBS240  United States
CBS240's Avatar
Forget the second power bridge. It really is transient current demands that a large capacitor bank works to provide. Just use the main filter capacitors and follow them with small resistors, and then to the rest of the capacitors in parallel. IOW, CRC filter. As long as there is a series resistor to the large capacitor bank driving the circuit, the smaller ones will not surge enough current to overload the bridge/transformer during power up. (hopefully ) Also important to keep AC power current (100/120Hz) and audio signal currents from flowing in the same PCB tracks or wires, thus aiding PSR. It is important that layout to the ground point also separates the return currents for these caps. Don't forget that the supply capacitors are part of the amplifier.
All the trouble I've ever been in started out as fun......
Old 24th March 2015, 08:48 PM   #9
Bigun is offline Bigun  Canada
Bigun's Avatar
To ensure that the good quality caps are the ones that the amplifier experiences for best sound you want them to be where the signal current flows. The signal current will flow through the path of least resistance, as CBS240 says. This means you want to place the audio quality caps close to the amplifier itself, ideally on the same PCB or very close by (but away from hot heatsink) because this minimizes the inductance of wiring between the caps and the amplifier - in other words it minimizes the impedance.
Between the filter caps and the amplifier local caps you can put some resistance like CBS240 suggests or use chokes to isolate the two capacitor banks in order to keep the signal currents out of the main filter caps (except for low frequency). I used a pair of common mode chokes wired to ensure that the dc current through the chokes is balanced: TGM9 - my version of the JLH '69 Class A amplifier
And put the rest of the filter caps further away from the amplifier, near the rectifier and transformer so that the charge pulses are going through short wires that are twisted together to minimize any noise coupling into the amplifier.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 25th March 2015, 04:02 AM   #10
One advantage of my scheme I can envisage is that the short charging currents to the main filter, from the transformer will be reduced in current amplitude due to an help from the booster capacitors.
Definitely there will be some very odd charging waveforms according to the value of the caps and the inductance it sees. This will be differing according to the load currents and will be highly unpredictable with music transients.
Gajanan Phadte
Single supply class AB amp, with two outputs per channel, how much idle current? Welcome Solid State 19 1st June 2013 02:03 PM
Seek Class AB PWD AMP +/- 80VDC Regulated Supply ckwong99 Power Supplies 1 25th December 2011 10:05 AM
10 W Class AB amp: Adapting Single Supply to Dual Supply jonatmudd Solid State 13 18th March 2011 07:02 PM
Class AB car amp, switchmode power supply, what rails?? SkinnyBoy Solid State 4 8th December 2003 02:26 PM
RC supply filter in Class AB amp tiroth Solid State 2 19th April 2002 07:44 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
