Sony TA-AX5 power supply, No Output, Please Help - diyAudio
Old 16th March 2015, 12:14 PM   #1
Default Sony TA-AX5 power supply, No Output, Please Help
Hi All,
This is my first post. I have some very basic perhaps inadequate - trouble shooting skills, so please be patient.
As a matter of course, I have replaced all the electrolytic capacitors C906, C911,C912, C913,914, C915,C916,C917,C918 but there is still no output from this supply. Voltage across coil L901 measures 330v DC (320V DC)
All resistors R901,902,903,904,905,906 measures ok out of circuit and Transistors Q901,902,903,and 904 measures ok in circuit.
It seems that the oscillator has started but oscillation cannot be maintained. The final voltage across C and E of Q902 is 14.3mv (40V) and C and E of Q901 is 0.665V (31V)
The voltages in parenthesis are reference voltages from the Sony TA-AX4 which uses a almost similar power supply.
The value of the installed R906 is 30 Ohms and not 22 Ohms as indicated in the circuit diagram, I do not know if this will cause the problem.
The amplifier did power up intermittently, approximately 1 time out of 100 power ups. During the time that it powered up normally, all the voltages in the power supply measures correctly.
Thanks for reading and any help appreciated.
Old 17th March 2015, 03:06 PM   #2
Anyone ???
Old 17th March 2015, 03:53 PM   #3
JonSnell Electronic's Avatar
As I was the owner of an Authorised Sony Service Centre for almost 30years, Sony did not recommend repairs for this type of power supply as there is a serious safety issue involved with repairing these unless highly qualified to do so. There was no technical backup and a replacement item was recommended. That was many years ago so I doubt there is any working stock left.
All I can suggest is check capacitors and the feedback loop Q902/2 etc. Mind your fingers as the capacitor (C419) stays charged with a lethal voltage, for some time!
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 17th March 2015, 06:42 PM   #4
Welcome is offline Welcome  France
Welcome's Avatar
I recommend pulling and testing all semis out of circuit. If I recall, high voltage transistors of this era were not so good, and a common cause of failure.
Old 29th March 2015, 03:44 AM   #5
Default Power Supply Repaired
Thanks to those who replied and sorry for the late response as I was waiting for parts from farnel.
For those who are interested, two film capacitors (C907 and C908) were replaced and the power supply can now maintain oscillation
Thanks.
Old 29th March 2015, 09:43 AM   #6
Welcome's Avatar
Interesting. How did you come to this conclusion?
Old 1st April 2015, 01:42 AM   #7
Default Sony TA-AX5 Power Supply
Simple, I came across this site and learned that the two capacitors were responsible for the oscillation of the power supply:
Free Translation and Professional Translation Services from SDL
Since both of them were .33uf, there were basis for comparison and I found that one of them were faulty using the capacitance range of my trusty sanwa analogue meter
Old 8th May 2015, 03:45 PM   #8
Default TA-AX5 resetting system and freeze problem
Hi all, i have the same model, my problem is when i turn on the unit, powers on normally, but when i turn the volume up and reaches certain level (aprox -30 db) resets and the volume go down to -60 db and passes automatically to tuner input. If i try to volume up several times the display turns off and the unit freezes, i have to power off and wait 5 minutes to turn on again. Ive checked the service manual and all button functions goes directly to the IC701 sony upd553c-141 which control them but i dont know if maybe is another component (like X701 crystal between pins 1 and 42) which causes this IC to behave wrong! any clues?
Thanks!
Sony TA-AX380 does not power up andreyambalov Solid State 3 30th October 2014 10:05 PM
Sony ta-fb940r humming after transformer replacement 5 connections on sec output ?? homertooties Solid State 1 24th June 2012 08:29 AM
Sony TA-313 vs Sony TA-F4A........which one??? mark31385 Solid State 10 30th November 2011 07:46 PM
Advice needed: Output stage in Sony TA-E9000ES (CXA8042AS DAC) Groundloops Digital Source 2 22nd June 2011 03:20 AM
Sony amp Ta-n611 output prob birch Solid State 0 17th August 2008 02:13 PM
Copyright 1999-2017 diyAudio
