Simple Mosfet amp -HELP - diyAudio
Old 11th March 2015, 08:15 PM   #1
CSOLEE is offline CSOLEE  United States
Default Simple Mosfet amp -HELP
Need help. Built the following amp using FQA28N15 and 36P15 Mosfets. Based on the VSSA amps. Wanted a nice small board 10x10cm, everything fits. Did not want to buy anything so used what I had. The LTspice simulation works fine but when I tried a prototype out, the gate resistors for the outputs smoked when I got the output bias voltage to about 7.2 volts. Seemed like the outputs turned on and took off, voltage across the output source resistors kept going up. Any ideas? Bad design? I know the original VSSA circuits used Laterals.
Spice schematic attached.
Old 11th March 2015, 08:56 PM   #2
Did it Himself
richie00boy's Avatar
How did you get 7.2V of bias voltage across those two diodes?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 11th March 2015, 08:57 PM   #3
JonSnell Electronic's Avatar
Send a message via Skype™ to JonSnell Electronic
Output FETs are the wrong polarity or are drawn wrong. N channel have the arrow pointing out. P channel, pointing in, like standard semiconductors.
Support for Flying Mole, Allen & Heath, Valve amps, older designs & 2CVs. www.jonsnell.co.uk
Old 11th March 2015, 08:58 PM   #4
Correct schematic attached
Old 12th March 2015, 05:30 AM   #5
Old 12th March 2015, 12:13 PM   #6
Lazy Cat's Avatar
First One VSSA
Old 12th March 2015, 12:14 PM   #7
Lazy Cat's Avatar
Inventing the wheel
First One VSSA
Old 13th March 2015, 08:26 AM   #8
Did it Himself
No they don't. He has drawn them correctly.
Old 13th March 2015, 08:35 PM   #9
Originally Posted by Lazy Cat View Post
Inventing the wheel
HA, HA, you are so funny the lazy cat.........................
Old 13th March 2015, 09:39 PM   #10
nigelwright7557's Avatar
The bias circuit is very poor, you need a proper Vgs or Vbe multiplier or you will get cross over distortion.
PCBCAD51 pcb design software. http://murtonpikesystems.azurewebsites.net/
Simple all N-channel MOSFET amp scholl Solid State 6 25th January 2013 01:00 PM
Question on a Simple Lateral MosFet Amp quinnling Solid State 2 11th October 2011 06:34 PM
Simple MOSFET amp bokakob Solid State 46 9th August 2007 12:42 PM
Simple MOSFET amp problem luixssj3 Solid State 26 9th October 2006 01:54 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
