Idea for an high quality amp with 50Vdc power supply - diyAudio
Old 10th March 2015, 04:35 PM   #1
bading is offline bading  Italy
Default Idea for an high quality amp with 50Vdc power supply
I have an used toroidal transformer with power 300VA and two outputs from 35Vca. I want to build an audio amplifier. I saw schemathics F5 and P3A but all work with lower voltage. Any idea for an high quality amp with 50Vdc power supply?
Thank's
Old 10th March 2015, 05:18 PM   #2
vzaichenko's Avatar
Send a message via Skype™ to vzaichenko
Arrow High-performance singleton CFA
Hi Bading,
I can recommend one of my recent designs - Compact CFA v2 "IRFP". Rather simple yet high-performance.
>Final schematic<
>Live-measured spectrums<
>PCB by Marc (Idefixes)<
There's also my version of the PCB - the one I used for my build.
I can send you the Gerbers if you like.
Pictures show MJL BJTs at the output, however my favorite option has got "IRFP" HEX-FETS there, providing around 140W @ 8 ohm of high-quality power.
Valery
If you can't explain it simply, you don't understand it well enough (c) Albert Einstein
Old 10th March 2015, 05:25 PM   #3
Bigun is offline Bigun  Canada
Bigun's Avatar
Don't pay any attention to Valery, he knows my amps are the best (just kidding)
and they have both BJT and FETs at the output !
TGM8 - an amplifier based on Rod Elliot P3a
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 10th March 2015, 05:29 PM   #4
vzaichenko's Avatar
Gareth - no doubt
Just saw - nobody answers
Old 10th March 2015, 06:18 PM   #5
Bigun's Avatar
There are a lot of amps that can work at the higher voltage. It probably depends on how much you want to do yourself - there are some nice options for ready built modules and also kits on eBay etc. and there are a number of designs on the forum as well as some pcb's available from the forum shop. Budget is another consideration.
You can also use these transformers as 0-50V supply and build an amplifier with a single rail but without output capacitor (some don't like that but I say make your own choice).
Old 10th March 2015, 06:44 PM   #6
donpetru's Avatar
AV400v2:
AV400v2 - Another 400W Hi-Fi audio amplifier with remarkable sound
AV400v2 and GX400 audio amplifier projects
PCB Design Services - for prototypes OR serial products, Today Tehnium and Forums
Old 11th March 2015, 05:18 PM   #7
Thank's for all!
Originally Posted by Bigun View Post
You can also use these transformers as 0-50V supply and build an amplifier with a single rail but without output capacitor....
Very intersing!
Do you give me a link to this example schematic?
Dario
Old 11th March 2015, 05:45 PM   #8
Bigun's Avatar
Here's a rather good example (excellent performance): MJR7-Mk5 Mosfet Power Amplifier Design Notes
It uses LatFETs not HEXFETs but you asked for an example - many amplifiers were built with output capacitors in the past. At that time the quality of available capacitors was poor, today there are excellent large value caps available. Some time with Google will help you.
Also: Bigun's TGM8 with Single Supply
Old 23rd March 2015, 06:01 PM   #9
I decided for Rod Elliot P101 project!
Thank's for all
High quality amplifier power supply for sale supernet Swap Meet 4 19th December 2008 10:22 AM
Need high quality prebuilt power supply for DAC zhai Digital Source 9 5th December 2006 12:47 PM
UCD AD180 + High Quality power supply SEIJI Swap Meet 1 10th September 2006 03:06 PM
High-quality power supply for a gainclone not needed ? Blitz Chip Amps 35 1st February 2004 09:24 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
