Nakamichi PA-7EII Problems... - diyAudio
Old 3rd March 2015, 10:38 PM   #1
Default Nakamichi PA-7EII Problems...
Hey guys,
A friends got his hands on a hand-me-down Nak set, incl tuner, preamp and a PA-7EII. Problem is, when he got it, all it did was blow line fuses So anyway, he's asked me to try help him get it going.
First thing I noticed was that it appeared that the spark killer on the limiter board was bust, so replaced that with discrete resistor and cap. Still wouldn't budge, and I noticed that the primary wasn't being engaged at startup and continued to blow fuses.
Tried shorting across the soft-start relay terms and the lights came on for half a second and then the fuse blew again. Replaced the relay with a new solid-state dude, but the same thing happened, so I ruled out the relay and put the stock unit back as I figured it was ok.
Checked out the ballast resistor and that seemed blown. Replaced it and started it up again and the new alu-jacketed ballast resistor blew into a couple of pieces with a huge bang, but the lights came on just before.
So I'm kind of at a loose end from here on. It seems that something has made this amp intent on blowing the 2R2 ballast resistor for the soft-start.
Any help/ideas would be appreciated! And by the way, I've checked every answer to this on the net and haven;t yet found a probable solution.
Cheers!
Old Yesterday, 01:11 AM   #2
You need to hook it up to a dim bulb tester before you permanently damage something and turn it into a boat anchor. The DBT will at least keep the fuses from blowing and allow you to begin troubleshooting where the problem is at.
If it were me I'd disconnect the amplifier channels from the PS and then with it connected to the DBT power it on. The DBT should glow brightly for a second and then dim. You may have a dead rectifier or e-cap and this test will identify where the problem is at.
KC
Old Yesterday, 08:36 AM   #3
djk is offline djk
djk's Avatar
You need to check the outputs for shorts, and the rectifiers and main filter caps as well.
Candidates for the Darwin Award should not read this author.
Nakamichi PA-5 and PA-7 Design Help Requested Apogee Pass Labs 20 30th May 2013 04:54 PM
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 01:37 PM
Nakamichi OMS-5EII/7EII weak error correction Salar Digital Source 5 17th December 2007 01:43 AM
Nakamichi OMS-7EII ManUtd Digital Source 2 23rd October 2003 03:46 PM
Nakamichi OMS-7EII ManUtd Digital Source 0 21st October 2003 02:47 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
