Usable distortion analyser for Pre-/Amps
Old 28th January 2004, 08:41 PM   #1
MichaelB is offline MichaelB  Germany
Send a message via ICQ to MichaelB
Question Usable distortion analyser for Pre-/Amps
I've just searched and found several threads on this topic...lots of links
to free SW-packages and surplus distortion analysers, like the HP33x.
But I wonder if these are really usable for audio electronics? Most of
the SW-packages I found are basically designed for loudspeaker design
with measurement of electronics only as a goodie.
I wonder if a resolution for THD of 0.01% is really usable for SS-amps
and esp. pre-amps where you can (more or less easily) reach THD
values of <0.05% over the complete audible range...?
Are there any recommended computer based measurement solutions,
really *usable* for serious diy-electronics, not necessarily free but also
not in the price region of an AP-Analyser??
Michael.
Old 29th January 2004, 07:46 AM   #2
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
Thumbs up rmaa 5.2
rmaa 5.2 gets my thumbs up..... Not that I'm experienced in this area (in general) but I've been playing with it, and as far as I can tell it is a usefull tool, and I think if you have a good enough soundcard the resolution is probably not too bad. (at least for testing power amps).
here are links to tests I have done with RMAA. Note that the actual measurements are much higher resolution than these html reports would indicate, with full zoom capabilities.
1st loopback test on my sound card to get a base level to work with.
http://home.swiftdsl.com.au/~tonywww...20loopback.htm
second burned the test tones to cd and tested my DVD player, to my surprise the distortion figures were lower, which means that the DVD player does a better job of generating the test signal than the sound card. Note that there is something very odd going on with the crosstalk on one channel, did this when I tested the computers cdrom drive too, so suspect something went screwy with burning the cd.
http://home.swiftdsl.com.au/~tonywww...%2044_1Khz.htm
finally a test of my amp which you can see has "some issues" !!!!
http://home.swiftdsl.com.au/~tonywww...approx_25W.htm
RMAA can be got here: http://audio.rightmark.org/ Oh goody 5.3 has come out and apparently the audigy II ZS performance is even better still!!! Time for some more playing me thinks
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 29th January 2004, 10:10 AM   #3
Pjotr is offline Pjotr
Pjotr's Avatar
Default Re: rmaa 5.2
Hmm… Tony,
Looks RMAA does the A-weighting on the FFT result and as such curves the noise floor also. This is more confusing than helpful.
Cheers
Old 29th January 2004, 10:16 AM   #4
just another
wintermute's Avatar
Oh well...... I'ts been usefull for me in showing up gross problems in my amp
Not 100% sure what you mean (as I said I'm not really experienced in this stuff). Are you talking about the combining of Noise + THD results?
edit: actually I just went back and looked at the results, and the A-weighted results are worse than the other results, which I do remember confused me at the time, since I allways thought that A-weighted results generally looked better (again my naivety may be showing here).
I guess the other thing I would say is a limitation with RMAA, is that RMAA (for the HTML reports) only chooses one channel for doing it's "analysys" I think it's better looking at the "raw" graphs.
Tony.
Some of my photos
Old 29th January 2004, 12:06 PM   #5
tschrama is offline tschrama  Netherlands
With a good soundcard and a 10 dollar oscilator I have achieved THD resolutions down to 0.00165 % about -97dB. I think that's about as low as you can get with a soundcard, allthough I've heard someone reaching -105dB THD. I use a Creative Audigy 2 ZS soundcard. The strange thing is that when I use RMAA 5.2 for 24bit support measurements, I cannot improve behond the above number... 16bit or 24bit give the same results both in THD and dynamic range.. hmmmmm makes me think..
Thijs
PS
allmost forgot, the software... I think it's been said before:
RMAA 5.2,
DAZYWEB LABORATORIES SA-3002 V1.33,
spectralab ver 4.32.17,
http://www.audiotester.de/ .... etc
Old 29th January 2004, 01:53 PM   #6
maylar is offline maylar  United States
Has anyone ever compared these software analyzers against a real calibrated piece of test equipment? I have a real hard time believing that a PC soundcard can measure distortion down that low.
dave
Old 29th January 2004, 03:28 PM   #7
I knew someone would post a sceptical remark... I was sceptical myself too at first...
I haven't done any comparison against a calibrated device. I have compared the various software solutions againstb each other and they give the exact same results. I trust the mathmatics is done correct by the programmers, and that my AMD CPU doesn't produce invalid numbers and that the underlying nummerical-algorithmes are correct.
So once the bits are generated, I have nothing to worrie about... It's only in the ADC process that you might get worried.. the quality of the ADC is the bottleneck. But dittering and averaging the signal, together with carefull signal amplitude adjustment makes it possible to achieve such resolutions..beyond 16bit
Using a good notch filter, one should be able to measure even lower THD, only limited by the oscilators residual THD..
Goodluck,
Thijs
Old 29th January 2004, 05:24 PM   #8
Pjotr's Avatar
Found Audiotester one of the most useful progs for doing such measurements. Although it is not free it is not that expensive. What the residual distortion is, can easily be measured by connecting input and output of the soundcard with a short cable. The distortion you measure then is the combined residual distortion of the signal generator and recording device. It is just what it is: the measurement floor of your test set-up.
Looking at the harmonic profile tells you a lot more than THD and/or THD+Noise figures alone. And for this a soundcard+software tells usually a lot more than an ancient second hand standalone distortion meter.
Cheers
Old 30th January 2004, 08:32 AM   #9
EDUM is offline EDUM  Netherlands
I have been looking in measuring with "soundcard solutions" for quite some time. After a few internet searches I got confused. So I wrote a document just to order my thoughts. There are a lot of products, software packages for different audio purposes. So by categorising a lot them the picture for me became clear.
What I realy want is a product which gives the posibilities oscilloscope, FFT and wave-generator with a very high precision/ resolution on my PC.
So basicly that is a hardwarebox and some software. Software solutions are available from good freeware to expensive professional.
The most important is the hardware. The old schoolbooks say that the quality of your measuringequipment should be a class better as the things you would like to meausure.
Looking at our "Audio" needs most soundcards specs are to close to be comfortable to the values we like to measure. If you want to have a 100 dB SNR and a DC-100kHz range the number of hardware options are limited. Unfortunately they are absolutely not affordable.
However 24bit 192kHz AD converters become more and more available. So looking at professional "soundcards" and recording solutions might give a solution in the near future.
Personaly I find a product like the ESI Quatafire most promising(even payable!). I understood the Quatafire must become avavailable real soon Unfortunately they tell that already for more than half a year for their firewire range of products...
So yes I believe a solution is near!
(and I can finish that document)
Ward
The vast number of parameters involved in human hearing make imperfect designs certain.
Old 30th January 2004, 12:13 PM   #10
Now I can be mistaken, but.... I just checked the ESI site for this Qatafire 610 product. Now the AD converter is a 96kHz one instead of a 192 kHz... Specs are subject to be changed... May be an explanation for the delay?
Ward
Usable distortion analyser for Pre-/AmpsHide this!Advertise here!
Distortion analyser circuit steevo Solid State 12 21st July 2008 01:42 AM
Looking for informations on Marconi TF2331 Distortion Factor Analyser bembel Tubes / Valves 12 27th November 2006 03:46 PM
IM Distortion Analyser Alain Dupont Parts 2 6th January 2005 02:48 AM
HP334A Distortion Analyser Netlist Swap Meet 1 14th October 2003 10:33 PM
HP333A Distortion Analyser Netlist Equipment & Tools 12 13th October 2003 09:40 PM
