Old 28th January 2004, 03:49 AM   #1
Default Power supply for Car amp
Hi all, Can I use a 10-0-10v ,1000va torroid in conjunction with caps etc to power a class D car amp?
Old 28th January 2004, 04:59 AM   #2
Easyamp's Avatar
Where will you get your primary voltage from?
The class of amp is a seconadry to what the amps input voltage is, if it's a car audio amp 12~15v then yes, you'll get about 14+ volts D.C. from one leg of the supply in bipolar mode. I sugest you use the transfo in half duty mode it'll give you more or less the same out as a single leg, but load both seconadry instead of one.
Old 28th January 2004, 05:05 AM   #3
Workhorse's Avatar
Arrow Commentable Thoughts
Hey Friend PLZ CLARIFY UR STATEMENT!
Ampman
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
Old 28th January 2004, 09:41 PM   #4
Sorry Im a bit dense when it comes to these things, The negative terminal of the amp attaches to where?
Split Voltage Switching Power Supply for Power Amp vectorplane Swap Meet 2 23rd April 2011 11:48 PM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 05:10 PM
Can i use a computer power supply to power audio amplifiers? destroyer X Solid State 91 25th September 2006 04:36 AM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 02:21 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 01:30 PM
Copyright ©1999-2013 diyAudio
