Marantz sr5002 only takes input in 1 channel
Old 10th February 2015, 02:21 AM   #1
srinath is offline srinath  United States
Default Marantz sr5002 only takes input in 1 channel
OK atleast for me, this is a first.
Its got all channels of output. But it only has 1 working input channel. Only the white RCA is working, the red RCA isn't taking input in tape or CD or anything.
Almost like I should go looking for a missing jumper - except, its not got any. It has 5.1 preouts and 5.1 in's. But not pre out main in jumpers.
Anyone had somehting like this happen ?
Thanks.
Srinath.
Old 13th February 2015, 03:15 PM   #2
east electronics is offline east electronics  Greece
east electronics's Avatar
Try to see what happens if source direct is pressed ...As a function source direct will bypass all tone control circuits sending the signal directly to the amplifiers .
If this works means that the digital board of your amp is toasted and either to expensive to fix or impossible to get .
Amp might be usable for many years to come in source direct mode
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 13th February 2015, 04:50 PM   #3
I screwed up in the setup menu.
Its fine now.
Thanks.
Srinath.
Marantz sr5002 only takes input in 1 channelHide this!Advertise here!
Single-cycle symmetric (N - P - N channel + P - N - P channel) repeater plated input FEDOSOFF Solid State 56 7th May 2017 02:08 PM
Deer Takes Down Hunter billjames The Lounge 91 1st December 2011 02:18 PM
Another G Chang takes its first steps Justin Wake Full Range 8 22nd July 2008 02:46 AM
marantz hum on one channel ian21 Solid State 0 14th June 2008 10:54 AM
I hope nobody takes this the wrong way... ptwining Class D 100 26th January 2008 05:11 AM
Copyright ©1999-2017 diyAudio
