Request redrawing schematic from pdf to eagle - diyAudio
Old 8th February 2015, 12:09 PM   #1
Default Request redrawing schematic from pdf to eagle
I would like to bulid elctrocompaniet amplifier from pdf. I have got schematic a part list etc. I just need pcb or schematic in eagle. Can somebody help me and redraw it from pdf to eagle. I will handle it from there. Thanks
File Type: pdf Electrocompaniet 25W Lostroh-Mati Otala engl language.pdf (121.0 KB, 68 views)
Old 8th February 2015, 12:19 PM   #2
vzaichenko's Avatar
Send a message via Skype™ to vzaichenko
Oskar, if you can handle it in Eagle - why can't you draw it in Eagle?
Valery
If you can't explain it simply, you don't understand it well enough (c) Albert Einstein
Old 8th February 2015, 12:47 PM   #3
I can't draw schematics in eagle. But I can do it in express pcb so I'm trying to do it there
Old 8th February 2015, 03:51 PM   #4
Welcome's Avatar
Eagle is a very poorly designed program (probably by engineers), but despite all that, it IS almost easy to learn how to do it, but only if you get help.
So therefore, this tutorial is mandatory reading. I recommend going through it, because once you know how to do it, Eagle is a very powerful tool, and tons of fun to use.
https://learn.sparkfun.com/tutorials...agle-schematic
Old 8th February 2015, 04:19 PM   #5
msdin is offline msdin  United Kingdom
This may help with your pcb quest.
https://www.mediafire.com/folder/sef...44/oldpcbfiles
I may still have the artwork but I think it was done in Autocad.
I did make a set of revised pcb to repair my my faulty amp as the original track are very fragile.
My amp has a faulty transformer so I've not been able to test the new pcb's.
I've been looking for a working one for a number of years and just this week I've found one, it should be deliver this week.
Sharif.
Old 8th February 2015, 09:12 PM   #6
Sharif.
Is this double sided or "normal" board? I'm only worried about BCY87 and BCY89. Where I can get them from? Also I have got a question can somebody give me an opinion about an schematic of an amp I found on polish forum Zapodaj.Net - Darmowy hosting zdj?? i obrazków bez rejestracji! - 3a5bcfac33a29.bmp (link to schematic) attachment is Bill of materials.
File Type: txt ELEMENTY.txt (516 Bytes, 12 views)
Old 9th February 2015, 03:48 AM   #7
The first hurdle for a beginner is, the user should include the libraries for use and only then he can draw a schematic.
Once that is done, everything else is easy and is as shown in the link above.
Gajanan Phadte
Old 9th February 2015, 08:17 PM   #8
The boards are double sided.
With regards to the BCY87 and BCY89 they are obsolete.
I think they could be replace with match pair of BC547B for the BCY87 and match pair of BC549B for the BCY89.
Old 9th February 2015, 08:33 PM   #9
If the boards are double sided that's a big problem for me, but anyway I have decided I will make an amplifier from schematic I have attached in my previous post. Good message is I can replace BCY87 and BCY89.
Old 13th February 2015, 09:00 AM   #10
The power supply for the original '25 Watt Class A' is 32-0-32 volts for the front end and 26-0-26 volts for the output stage.
The C Core mains transformer size is between 500VA and 600VA.
Secondary Tapping's with approximate current.
2 x 20 volts @ 10.0 amps each winding.
2 x 26 volts @ 2.5 amps each winding.
1 x 26 volts @ 0.5 amps.
"how to change output pdf's dpi" in EAGLE ? Al1B Software Tools 4 23rd June 2011 09:22 AM
First try at an Eagle Schematic/board athos56 Tubes / Valves 15 4th November 2009 05:15 AM
Eagle soldermask request croccodillo Parts 2 12th November 2008 08:32 AM
Electronic schematic in PDF santosa Parts 0 3rd September 2005 10:55 AM
Mark Finnis' Aleph 5 schematic & Stuffing PDF Guiness Pass Labs 1 14th March 2004 02:56 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
