technics power transformer - diyAudio
Old 6th February 2015, 01:13 AM   #1
joshy is offline joshy  New Zealand
Default technics power transformer
Hi I have a technics sa t670 and cant find a service manual anywhere. I was hoping if any of you gurus had a idea on the specs ate so I can replace the transformer. Many thanks
Old 6th February 2015, 07:11 AM   #2
Mooly's Avatar
If there is no manual available then all you can do is 'work backwards' trying to deduce the DC value of the rails based initially on reservoir cap voltage. For example a 63 volt reservoir cap probably runs at say 50 to 55volts DC implying a 38 volts AC winding.
All very messy and I'll bet this model has multiple secondary's anyway. What is wrong with the original ?
Installing and using LTspice. From beginner to advanced.
Old 6th February 2015, 08:03 AM   #3
Max Headroom's Avatar
Location: West Australia, near to the beach, natural ambient sounds only.
What's wrong with the original transformer ?.
Most Jap transformers have a primary winding thermal fuse that can be replaced.
Dan.
Old 6th February 2015, 08:05 PM   #4
benb is offline benb  United States
A quick googling brings up this "power test" page, which gives rail voltage and output power, you can surely figure out a transformer rating from this:
Technics SA-T670 Power Test
Technics SA 626 blowing fuse before transformer rfitts46 Solid State 37 9th August 2014 11:37 AM
About power transformer of technics st-8077 tuner jorge2 Analog Line Level 0 21st June 2008 09:04 AM
Technics SU-X840 mains transformer Trevor99 Parts 4 26th February 2008 01:29 PM
Technics OFC transformer gareth Solid State 1 3rd February 2008 01:03 PM
The lego-technics transformer winding setup svokke Tubes / Valves 6 22nd November 2003 12:30 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
