TDA7297 output - diyAudio
Old 27th January 2015, 09:39 PM   #1
AMDV is offline AMDV  United Kingdom
Default TDA7297 output
Hi guys,
I have a small TDA7297 stereo amp (15W +15W).
Is acceptable to connect both the L and R outputs to a single speaker for mono operation (assuming the speaker is not overpowered)?
DV
Old 27th January 2015, 11:00 PM   #2
sreten is online now sreten  United Kingdom
No. You can parallel the inputs, but you need to add say 0.22R series
resistors to all 4 outputs before combining them to 2 terminal mono.
Well that is the theory, but in practice it is hard to say if they are
really needed, I suspect due to internal chip details not given in
the datasheet, perhaps not. But better safe than sorry.
The small resistors are needed to absorb any small voltage
DC offsets and AC gain differences between the two amplifiers.
Those sort of resistances may already be in the chip.
IMO they probably are, but I'm not guaranteeing anything.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 27th January 2015, 11:26 PM   #3
Destroyer OS.'s Avatar
It's been done, paralleled (no resistors). It may not be as accurate. They're cheapish, so trying two chips might be a nice idea, and not paralleling.
The amplifier is in balanced mode internally so you can't bridge it or connect - output to PG.
Old 28th January 2015, 02:10 PM   #4
Great info guys, thank you very much for helping me. In that case I might just join the two inputs and just use of of the outputs. Is any hard done leaving an output disconnected?
Old 28th January 2015, 02:32 PM   #5
No, not at all. Very few speaker amplifiers are not open-proof, and even fewer of these would qualify as solid state.
Old 29th January 2015, 01:48 AM   #6
It has built in protections.
TDA7297 and Karlsonator prezden Class D 22 25th September 2014 01:43 AM
TDA7297 Amplifier Zebrawood cervelorider Swap Meet 0 26th January 2014 12:53 AM
TDA7297 grounding danny92 Chip Amps 4 31st January 2013 10:43 PM
TDA7297 ground paths danny92 Chip Amps 5 30th December 2012 08:13 PM
TDA7297 how good Paswa Chip Amps 4 27th June 2008 05:51 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
