Akai AA-6100
Akai AA-6100
Old 23rd January 2015, 07:21 PM   #1
jakelm1975 is offline jakelm1975  United States
Default Akai AA-6100
This should be fun.
Top of uncles closet, tucked away. And still works!!
Time for upgrades. And cleaning.
Old 23rd January 2015, 08:48 PM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
Cleaning yes but if it works properly, leave it alone!
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 23rd January 2015, 08:50 PM   #3
Scratchy controls.. and hissing sound when turned up around half way..
What could cause he hiss, when volume turned up? Maybe the treble control?
Old 24th January 2015, 01:44 AM   #4
ivandezande is offline ivandezande  United States
ivandezande's Avatar
Old caps can contribute to it, but it's just the gain amplifying a very small amount of noise if I understand what you are saying.
Old 24th January 2015, 01:57 PM   #5
Its a pretty audible white noise, probably from the gain. Unless turned all the way up, to there there is no resistance.
I just leave the volume all the way up to avoid the noise and use the source to control volume.
I would like to find a way to bypass the bass and treble Eq. And run this little amp as a straight forward amp.
Old 24th January 2015, 02:12 PM   #6
http://www.hifiengine.com/manual_lib.../aa-6100.shtml
There's the schematic. Find the power stage input trace and solder a shielded wire from those to rca jacks. But don't do anything that can't be reversed.
Old 24th January 2015, 03:40 PM   #7
Originally Posted by ivandezande View Post
Akai AA-6100 Manual - Four Channel Amplifier - HiFi Engine
I have the schematics,
Just jump the EQ board input straight to amp. This will also probably eliminate any unwanted gain/distortion from bass/treble and volume. Giving more of a flat response
Old 24th January 2015, 03:46 PM   #8
Of coarse might be alittle more tricky than just that.
Akai AA-6100Hide this!Advertise here!
need help akai aa 1200 reciever mause7mm Solid State 1 13th November 2011 09:22 PM
S: Schematics for AKAI AA-6000 Cobra71 Chip Amps 0 10th September 2010 09:21 AM
Akai AA-1030 schematic? TomWaits Solid State 2 9th November 2007 08:38 AM
akai aa-1020db Williams Audio Analogue Source 0 22nd January 2006 05:32 PM
Akai AA-5800 baggystevo82 Solid State 1 19th September 2004 03:45 PM
