Arcam 6 Plus Amplifier Repair - diyAudio
Old 20th January 2015, 04:07 PM   #1
Default Arcam 6 Plus Amplifier Repair
Hi all,
I have an Arcam 6plus which failed to power up. I took the lid off and noticed that the main power input fuse had blown. I know the very basics of amplifier repair so i checked the continuity of the output transistors and sure enough one side was shorted. I replaced the blown side with new and it then powered up fine so i then adjusted bias for both channels at 4mv.
My problem is that now it still tends to blow the main fuse from time to time (probably 1 in three power ups) but when on is absolutely perfect. It's like there is a big power surge on power up as when looking at a newly fitted fuse as i power up you can see it surge ever so slightly.
Any help would be much appreciated, thank you.
Old 20th January 2015, 04:44 PM   #2
Send a message via Skype™ to JonSnell Electronic
What model is Arcam 6 plus? I can't find a schematic!
Support for Flying Mole, Allen & Heath, Valve amps and older designs. www.jonsnell.co.uk
Old 20th January 2015, 04:47 PM   #3
Mooly's Avatar
Sounds like you have fitted non time delay fuse in place of a T or AT type.
Installing and using LTspice. From beginner to advanced.
Old 20th January 2015, 04:55 PM   #4
It's an Arcam Alpha 6 Plus.
The correct fuse is T1A25 and at first i used a non time delay 1A which it blew on second attempt, the only fuse i had to hand was a non time delay 1.6A which it blew on the third attempt. I did think about this but the only time delay fuse i had was a 1A which it blew instantly.
I will try a time delay 1.25 and see if it sorts it.
Thanks.
Arcam Alpha 5 need help for repair AMTL Digital Source 10 22nd April 2013 03:08 AM
[HELP] Repair Arcam Alpha 2 - 240v CrustyD3mon Solid State 77 1st April 2013 05:45 PM
Arcam Black Box 2 Repair amc184 Digital Source 8 20th February 2011 08:29 AM
Arcam Alpha 8R repair advice tmr510 Chip Amps 1 12th September 2010 08:46 PM
Arcam Alpha 7 Repair big jim Solid State 1 26th June 2006 03:10 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
