Which amp should I build? - diyAudio
Old 25th January 2004, 04:26 AM   #1
Damian is offline Damian  United States
Default Which amp should I build?
I have Marantz SR7400 and Paradigm speakers. The receiver is rated at 105Wx7. I'm very new to the whole DIY on amp but I would like to build something that will give me about 150-200W/channel as I tend to push the receiver too much
Is it possible? If it is, which one should I check out?
Thank you!
Old 28th January 2004, 10:32 AM   #2
Hi Damian
Have a look at www.aussieamplifiers.com
I have quite a few amplifiers to build from 50 watts to 1kw
Anthony Holton
Old 6th February 2004, 04:54 AM   #3
Send a message via Yahoo to johnthetweeker
Take a look here:
http://users.otenet.gr/~athsam/power_amp_300w.htm
Me and my friend built a few of this with a few minor midifications. The sound is superb. Off the shelf components. Good component tolerance. Presently running them without any protection. Quite rugged design. Even no switch-on thump!
Have fun!
John.
John (not the baptist)
Old 6th February 2004, 11:34 AM   #4
tcpip is offline tcpip  India
Default What about the Opti-MOS?
If I were in your position, I'd try the Randy Slone Opti-MOS design. Schematic is available on his Website, and his books will give you a lot of background material and full information about the circuit, among other things. I presume you don't mind MOSFETs, considering the other suggestions too are along those lines and at high powers MOSFETs are easier anyway.
I found his books excellent, BTW.
Tarun
Old 6th February 2004, 05:48 PM   #5
lucpes is offline lucpes  Romania
Send a message via Yahoo to lucpes
Default Re: What about the Opti-MOS?
Tarun
I second that with no reserve!
I want to try and build my own DAC gareth Digital Line Level 3 3rd July 2009 03:20 PM
ZV9 build ingi Pass Labs 8 6th August 2006 02:40 PM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 07:54 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
Copyright 1999-2017 diyAudio
