Re: JLH 10 Watt class A amplifier
Old 12th February 2004, 08:30 PM   #11
DomKo is offline DomKo  Canada
Default Updated Version JLH 15W Amp
The following is the amp photo (front & back view).
Old 12th February 2004, 08:31 PM   #12
The following is the amp set (Passive Preamp & Finished).
Old 12th February 2004, 08:55 PM   #13
Dragance007 is offline Dragance007  Yugoslavia
Dragance007's Avatar
Send a message via ICQ to Dragance007
Realy good work
Old 13th February 2004, 12:49 AM   #14
dutch diy is offline dutch diy  Netherlands
dutch diy's Avatar
Send a message via ICQ to dutch diy
Default Re: Re: JLH 10 Watt class A amplifier
Originally posted by DomKo
Hi Diyer,
But I have one question about the hum. If there is NO input connection on the RCA, there is not hum. If there is an input (JUST RCA cable), there is a low hum (bee) sound. Either one of the cable connected to the amp. There is a small hum sound. You need to place your ear over the speaker to hear this bee.
How can I fix these hum sound?
Thank you very much.
DKO
Hi DKO,
My last JLH-amp (the updated 2003-ESL version) is dead quiet in my home setup.
It's noisy when unconnected cables are present.
However, when several weeks ago I hooked both amps to my son's dual-cd-mixing console (setup for a big party). I HAD A MAYOR hum on one channel when connecting one or two amps to my son's device.
I cured the problem with a simple box which was just a resistor based voltage divider on both channels. Which was needed any way to prevent speaker damage as the output of this console exceeded the sensitivty of my J-Amp.
Two weeks after that I had a similar hum at a test-setup to get some metrics done on my amp.
So, probably, I've might have mixed the wiring of the toroids on both channels. (both main wires are yellow)
I don't mind the noisy part with not connected cables. I'ts not interfering with listning to music (which needs connect cables)
Old 13th February 2004, 12:53 AM   #15
dutch diy's Avatar
btw this is how my amps look:
Old 13th February 2004, 12:59 AM   #16
dutch diy's Avatar
Default JLH-inside
Here's one inside detail pic taken during testing of the first channel.
Old 13th February 2004, 07:27 AM   #17
Default btw this is how my amps
Hi Dutch Diy,
Yours is Good Too.
The difference is that your amp is 'SEE THOUGH'.
I try to build it in one case. It is just enough space.
Finally, I add two pairs of cooling fan at the rear side.
I also need to adjust the fan speed to mininize the noise.
Now, the noise of the fan is hearing at about 1 feet. (It's acceptable).
I run the amp with about 12 hrs. The heatsink is kept at about 30 - 40 deg C.
I also test with signal generator from 50Hz to 22000Hz sine wave.
From the oscillograph, there is no visible distortion. I did not have another meter to test.
Enjoy with the music !
Re: JLH 10 Watt class A amplifierHide this!Advertise here!
20 Watt Class A amplifier JOE DIRTŪ Solid State 8 1st February 2012 12:41 AM
JLH 10 Watt class A amplifier DomKo Solid State 3 18th November 2003 07:32 AM
