Soft Start / Missing Cycle Detector / On-Off Mute Controller - diyAudio
Old 5th January 2015, 11:18 AM   #1
FdW is offline FdW  Netherlands
FdW's Avatar
Default Soft Start / Missing Cycle Detector / On-Off Mute Controller
All,
In the past few weeks I have developed a soft-start circuit with mute-control. The circuit is shown here. My question is, is there anybody interested in this project and if so what would you like to see (added/changed). Also I did select a mains transformer and the relays to be used (by me). What transformer/relay footprint would you like to see on a future board.
Have a look at the scheme and let me know what you think about it.
Frans.
Transformer: http://www.block.eu/en_US/products/720897.htm ECO 2003 Primair: 230 V Secundair: 12 V 125 mA 1.5 VA ECO2003-1,5S12
Relay's: JVN1A-12V-F Panasonic Electric Works | 255-2362-ND | DigiKey
NTC's: Amphenol 527-CL40 Inschakelstroombegrenzers | Mouser
Update:
Thanks to gmphadte, improved version @ Soft Start / Missing Cycle Detector / On-Off Mute Controller (Post #10)
Update:
Less components @ Soft Start / Missing Cycle Detector / On-Off Mute Controller (Post #11)
Update:
Two diodes less @ Soft Start / Missing Cycle Detector / On-Off Mute Controller (Post #14)
Update:
Enhanced muting timing @ Soft Start / Missing Cycle Detector / On-Off Mute Controller (Post #15)
File Type: png SSD BIG4BT V5, Power Switch; Events.png (21.7 KB, 328 views)
Old 6th January 2015, 11:05 AM   #2
FdW's Avatar
No one, please give me some sign of life
Old 6th January 2015, 02:14 PM   #3
Ketje is offline Ketje  Belgium
Something like shooting a mosquito with an elefant gun ?
Mona
Old 6th January 2015, 03:56 PM   #4
FdW's Avatar
Mona
Why not But it's all very cheap, a hand full of carbon resistors and about the cheapest transistors will do. Only the relay and transformer cost a bit. The three things that I absolutely need are the safety of the missing cycle detector, the control for muting and the soft-start for my amplifier (it has a 2KW linear PSU).
Total construction cost will be low(ish) so I thought maybe someone else wants a few or is interested in a thing like this.
Old 6th January 2015, 08:57 PM   #5
Shure for a diy-er a resistor more or less...
It was't ment that negative, more as a first cheap to get things going :-)
Mona
Old 7th January 2015, 06:58 AM   #6
The missing cycle detector...
you can make one with a 555.
Gajanan Phadte
Old 7th January 2015, 08:27 AM   #7
FdW's Avatar
Gajanan Phadte
The missing cycle detector here is made with one transistor.
Old 9th January 2015, 04:21 AM   #8
D8 anode and D4 cathode reaches the same point.
You can connect D8 after the bridge followed by C2. Take missing pulse sense at anode of D8.
Gajanan Phadte
Old 9th January 2015, 08:35 PM   #9
FdW's Avatar
Gajanan Phadte
Yep you can, but the bridge will be a 3n256 (or alike) and then the 'extra' 1n4148 is o.k.
Edit: On second thought the answer should have been 'Yes'
P.s. I have to check the timing for that, in the current scheme there is a 20mS gap and after that mod it is a 10mS gap (but full wave detect). So I will check that, thanks.
Old 10th January 2015, 08:13 PM   #10
FdW's Avatar
Gajanan Phadte
Attached is an updated schema, with updated timing to detect half-cycle-dropouts.
File Type: png SSD BIG4BT V5, Power Switch; Events.png (71.8 KB, 115 views)
Soft Start w Mute for LME49xxx Drivers jackinnj Power Supplies 3 12th January 2013 03:20 PM
Soft Start again marsheng Power Supplies 0 29th June 2010 11:09 AM
B+ soft start Gluca Tubes / Valves 2 3rd September 2007 02:04 PM
Tripath sleep/mute start up delay BWRX Class D 1 25th September 2005 09:45 PM
Soft start & Soft Switch circuit: can anybody help? m.parigi Solid State 95 22nd August 2005 04:32 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
