I've written a complete guide to building your own Leach Amp 200Wx2 in 2U rack mount - diyAudio
Old 4th January 2015, 09:43 PM   #1
Cool I've written a complete guide to building your own Leach Amp 200Wx2 in 2U rack mount
I have written a 37 page step by step guide with tons of supporting pictures, layouts, BOMs and hints to building your own Leach amp similar to the pictures you see attached. The guide will give you one click links to order every part needed. It provides prices for each component. You will find the the guide only in this thread and supporting documents in the next message and on Google Drive in the link below...
I couldn't upload everything to this thread due to the 1Mbyte size limit so I've provided a link to my Google Drive share below.
https://drive.google.com/folderview?...DQ&usp=sharing
Charles Robison
Leach Amplifier Assembly Guide v1.0 _pg1-20.pdf
Leach Amplifier Assembly Guide v1.0 _pg21-37.pdf
Old 4th January 2015, 11:34 PM   #2
Default Supporting files for Leach Amp Assembly Guide
I'm attaching the supporting files for the assembly guide here in case the Google drive link ever expires or breaks.
Leach Amp Building Accessories BOM.pdf
Leach Amp Chassis BOM.pdf
Leach Amp PCB BOM.pdf
Leach Amp Chassis Layout.pdf
Leach Amp Chassis Measurements.pdf
Leach Amp ExpressPCB Layout.pdf
Leach Amp Rear Panel Layout & Measurements.pdf
PCB files.zip
Old 7th January 2015, 08:16 AM   #3
Roushon is offline Roushon  India
Default Thanks!
Thank you very much for opening the thread and giving all information about the Leach amp. I am about to begin the project.
Roushon.
S. Roushon
Old 7th January 2015, 07:23 PM   #4
Default Good Luck! Keep me posted.
Glad to hear it Roushon. Keep me posted on how it goes.
Old 8th January 2015, 07:56 AM   #5
44250 is offline 44250  Serbia
44250's Avatar
Send a message via AIM to 44250
nice job!
Old 9th January 2015, 02:05 PM   #6
Neville is offline Neville  United States
Well done Charles on your documentation. I have never heard a Leach amp before, how would you compare it to lets say Pass F4 or Aleph J? Is there a cheaper alternative to the cost of the pcb's?
Old 9th January 2015, 02:16 PM   #7
Hi Charles,
Can you kindly post the schematic? I am new and I am not familiar with Leach amp. Is it supposed to be a very good sounding amp?
Old 10th January 2015, 01:05 AM   #8
Neville, I'm not entirely familiar with the Pass F4 or Aleph J but i've reviewed the output stage and in my opinion the Leach amp is a much higher end amp than these. Pass F4 is a class A amp running 50 watts into 4 ohm with two output transistors. Alepha J is running 25 watts (probably into 4 ohms). According to Dr. Leach, if you increase the bias current to run in a similar class A mode, this amp would be 1200Watts into 4 ohms but is not recommended as it cannot dissipate that much heat with the heatsinks in this design (The Leach Amp - Output Stage). The leach amp is an extremely robust and beautiful sounding class AB 200Watt amplifier with 4 output transistors (double the Pass 4 per channel).
As for the PCB cost... well unfortunately i have not found a cheaper option unless you are willing to build with friends or find others on this forum to divide the cost. It is cheaper per board to build 10 at a time than just 2.
Old 10th January 2015, 01:10 AM   #9
Alan0354,
you can find the schematic at the following link: http://users.ece.gatech.edu/mleach/l...aphics/ckt.pdf
let me know if that doesn't work and i'll post the schematic directly.
Also, absolutely a fantastic sounding amplifier. Extremely robust, elegant and most importantly sounds awesome! I do recommend running a pre-amp into the leach amp because it performs best with a high voltage, clean input.
Old 10th January 2015, 02:28 AM   #10
ostripper's Avatar
Nice build , man.
The leach does indeed sound nice.
My big brother "spooky leach" is quite the jaw dropper.
Never seen the "modern" TO-3p version of the original.
OS
Mongrel website , always current and updated :
http://www.fidelityforce.com/ostripper
2U rack mount chassis 20inch deep mcluxun Swap Meet 7 11th May 2014 06:45 PM
2u Rack Cab Great For Chip Amps!!! jeffshort2000 Swap Meet 1 5th December 2007 01:05 AM
FS: 2U rack mount aluminum project case elementx Swap Meet 1 26th December 2006 05:14 AM
2U rack cases len_scanlan Swap Meet 0 12th January 2005 11:06 PM
Leach Amp Guide wigginjs Solid State 2 27th August 2004 10:29 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
