Experiences with software thd, sine generating - diyAudio
Old 25th December 2014, 09:13 AM   #1
hahfran is offline hahfran  Germany
Default Experiences with software thd, sine generating
anyone?
I don't have neither a ultra low thd sine gen nor a precise thd analyser. I have a very old Terratec soundcard which has a wavetable for sine gen and a 24bit/192 kHz sample Julia soundcard. Any hint, experiences, software very appreciated.
Old 25th December 2014, 09:19 AM   #2
Rightmark Audio Analyzer is a popular program for measuring THD. Be warned that a good DIY audio amp will perform better than most soundcards.
"Some of the arguments conjure images of white-coated engineers with putty in their ears, designing audio equipment and not caring how it sounds, only how it measures. I have never met such a person"http://scopeboy.com/amps
Old 25th December 2014, 10:02 AM   #3
Thanx..priced in Ruble... should cost almost nothing these days...
Old 25th December 2014, 11:37 AM   #4
Looks like a simple spectrum analyzer software is not less reliable...
Old 25th December 2014, 12:45 PM   #5
There's nothing poor about the Juli@ soundcard. It's probably still up with current cards and certainly the connector quality and construction are superior to most others. The problem is cost and complexity of presentation quality software. Most is aimed at studio use and good products like ARTA are not so cheap to buy, whatever the number of features. It's still a great, comprehensive combination for a soundcard.
Quantasylum QA 400 USB card package is focused on distortion measurement but cheaper and simpler to install and get results fast: QuantAsylum QA400
Unfortunately all souncards lack a suitable wideband precision interface for measuring power amplifiers. You can build one (Member Pete Millet markets a PCB/panel label kit) but there aren't many you can buy simply or cheaply.
Ian
Old 25th December 2014, 02:44 PM   #6
I think a freeware spectrum analyzer software provided it interfaces to Juli@ drivers would do as an indicative tool, the key to success will be an interface, preferably battery operated, and even more preferably, transformer coupled . But that is already another, say, "dark matter" those audio transformers.
Old 25th December 2014, 08:28 PM   #7
vzaichenko's Avatar
Send a message via Skype™ to vzaichenko
I use the German software from >HERE<, commercial version. With Lynx L22 pro-grade sound card - very precise metering system. External loopback shows THD at the level of 0.0001% at 1KHz as well as at 20KHz (see attached). Output level is 650mV RMS here, sample rate = 192KHz.
Software looks inexpensive comparing to what the Lynx card costs
I love it
Valery
If you can't explain it simply, you don't understand it well enough (c) Albert Einstein
Old 26th December 2014, 07:28 AM   #8
vzaichenko thanx. Lynx is for professionals my objective is just an amp/speaker/listening room system for my own use. Thus the Juli@ card must do - otherwise I could just buy an active monitor speaker e.g. from JBL. I think only very few diy amp plus diy speakers could trump such an active monitor for around 1200 USD a pair.
However I would not trust any sort of a "precision" claim as the interior of a PC is electrically incredibly noisy. The , say, vintage Terratec card targeted at musicians - professional demo recording - came completely metal shielded.
Old 27th December 2014, 04:00 AM   #9
djoffe is offline djoffe  United States
I've been using the Behringer UCA202 Audio Interface (USB, so it sits outside the computer) along with the demo version of ARTA software.
ARTA Software
While not perfect, it's quite handy. Main thing it would need to take it to the next level is a precise stepped attenuator on the front end.
I'm sure there are better Audio interfaces, but this one was $30, and has RCA line level I/O, which is about the most useful for what I'm doing.
I'd certainly be happy to hear what other cards and software people are using.
Update My Dynaco
Akitika GT-101 Audio Power Amplifier Kit
Old 27th December 2014, 07:04 AM   #10
Originally Posted by vzaichenko View Post
... software from >HERE<, commercial version. With Lynx L22 pro-grade sound card - very precise...
Hi Valery
The screen for the 20 kHz THD doesn't show any response past 20 kHz.
If the response is filtered past 20 kHz then the THD will look very impressive, of course
Some sound-cards and/or software assume you don't want response past 20 kHz.
Fine for sound but bad for measurement, have you checked this?
Can you show the response past 20 kHz?
Best wishes and compliments of the season (even if it's not orthodox Xmas yet)
David.
Generating a 1 KHz sine at 10mvrms DreadPirate Solid State 14 16th December 2013 10:03 PM
LT AN67 Ultralow THD 10kHz sine oscillator group buy. Frex Group Buys 60 20th March 2013 11:54 AM
LTSpice way too high input sine wave THD Neutrality Software Tools 8 17th May 2011 03:53 AM
AN67 Ultra-low THD 10kHz sine oscillator PCB iko Swap Meet 6 25th September 2010 06:43 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
