LSR&D Leach Superamp bias problem - diyAudio
Old 19th December 2014, 09:52 PM   #1
Default LSR&D Leach Superamp bias problem
Hoping someone can help me here. I'm not able to bias up or down with the 500R pot in one of my Superamp monos. I can but only in a narrow 60 to 90ma range. I can't get it out of there, up or down. I've removed and checked the pot. Can someone please point me in the right direction? All I can think of are the bias diodes/resistors. Thanks in advance.
Old 19th December 2014, 09:57 PM   #2
AndrewT is online now AndrewT  Scotland
What is the bias voltage across the Vbe multiplier?
Does that bias voltage change as you adjust the VR trimpot?
regards Andrew T.
Old 20th December 2014, 12:23 AM   #3
Thank you for responding. Voltage is steady .976 regardless.
Old 20th December 2014, 09:17 AM   #4
thoroughly check the Vbe transistor, noting type (NPN, or PNP) and the orientation.
Check the VR is actually changing.
Check the currents flowing through the Vbe resistors.
regards Andrew T.
Old 20th December 2014, 02:10 PM   #5
Check loop connection of thermal compensation diodes or possibly defective pot.
Pinoy ikaw ay pinoy... ipakita sa mundo... kung ano ang kaya mo...
Old 20th December 2014, 04:06 PM   #6
I have 1.9mV through the VR and .64v through the fixed resistor. The transistor is a PNP MPS8093. The VR is definitely changing. I can hear it. In any case I replaced it but the old one functions identically so I know the pot is good.
Old 20th December 2014, 08:25 PM   #7
Correction. It's NPN functioning as it should. Conduction from base to emmitter/collector.Collector to fixed resistor, emitter to a zener diode.
Old 21st December 2014, 03:43 PM   #8
bump
Old 21st December 2014, 04:53 PM   #9
llwhtt is offline llwhtt  United States
Can you post a schematic? Maybe more people would chime in.
Craig
I found the schematic but no zener on the emitter of Q13, we need YOUR schematic.
Old 22nd December 2014, 02:08 PM   #10
Dr. Leach made it clear there isn't a schematic for this amp. I've taken photos of the board, front and back but can't upload them.
FS. Nice pair of LSR&D Leach Superamp monos Discopete Swap Meet 0 19th November 2012 05:03 PM
FS: 3 Leach project amps.+ LSR&D S.A. monos Discopete Swap Meet 0 27th May 2012 06:10 PM
Leach Low TIM 4.5 bias problem Craig405 Solid State 9 28th June 2010 12:04 AM
Leach Superamp Discopete Solid State 1 13th December 2009 07:58 AM
Leach superamp Opie Solid State 6 1st March 2002 05:29 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
