Old 23rd January 2004, 07:09 AM   #1
Default Converting unbalanced AF signal to balanced
Hello !
Anybody have some simple schematic for converting an unbalanced (RCA) audio signal (from PC sound card) to balanced and then back from balanced to unbalaced ? I need the schematic because I have to transport the audio signal from PC sound card to amplifier which is located 30m away from it. I'm searching for an simple solution because the quality of transmited audio is not so critical (it will be used for listening the music in an car repairing garage).
Another question is, can I use UTP (4 twisted pairs of wire inside) cable for the transport of balanced signal ? The UTP cable is not shilded ! I ask this because I have this cable installed already and if it is possible I would use it .
Thanx !
Some are born with more and some born with less so don't take for granted the life we've been blessed it's hard to understand thet we're only a guest and each one of us shall be put to life's test.
Old 23rd January 2004, 07:51 AM   #2
Frank Berry's Avatar
You can certainly convert the unbalanced line output of a computer sound card to balanced by using a transformer.
Once the signal is properly balanced it is perfectly okay to use unshielded cable. This is done regularly in broadcast stations.
Use transformers with a 1:1 turns ratio.
Frank
Old 23rd January 2004, 08:52 AM   #3
Ouroboros's Avatar
If you don't want to go to the expense of high-quality audio transformers, the SSM2141 / 2142 / 2143 chips from Analog Devices (www.analog.com) are widely used in the audio industry for driving and receiving from balanced lines. Although they won't tolerate the very high common-mode that a transformer will, I think you'll find they work well in the majority of circumstances.
Chris Morriss.
Old 23rd January 2004, 09:06 AM   #4
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
UTP will work well at transporting balanced audio under most circumstances.
Don't use other pairs for other signals such as Ethernet or telephone
Old 23rd January 2004, 09:10 AM   #5
Allied Electronics sells a 1:1 audio transformer which should do the job. Their part number is 227-0862. Price is $13.16 USD.
While this is not "audiophile" quality, it should provide acceptable audio quality for use in an automobile repair shop.
Frank
Old 23rd January 2004, 09:29 AM   #6
mrfeedback's Avatar
Car audio shops/wholesalers sell little isolation transformer boxes complete with RCA in/out connectors and are cheap.
They have E-core audio transformers that will work well enough for your application.
They also have speaker level to RCA level boxes too - I have used one of these to transport audio 50 m and it worked just fine.
Eric.
I believe not to believe in any fixed belief system.
converting and unbalanced in into a balanced input joyfulstudios Parts 2 12th June 2005 12:41 AM
Converting balance to unbalanced input diyman Solid State 4 7th March 2004 09:16 PM
unbalanced/balanced/unbalanced conversion using transformers vladimir Solid State 10 27th February 2003 06:54 PM
unbalanced or balanced theturtle Everything Else 4 5th January 2003 04:52 PM
Zen Balanced Line Stage Balanced vs Unbalanced macka Pass Labs 28 11th December 2002 06:18 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
