Metaxas Ikarus; problem with volume control - diyAudio
Old 8th December 2014, 08:56 PM   #1
krasnal is offline krasnal  United Kingdom
Default Metaxas Ikarus; problem with volume control
I got a huge problem with my integrated amp made by MAS.
As soon I'm starting to move stepped attenuator I can hear horrible cracking noise. Before I had normal alps pot I had same problem.
Please take a look a the diagram and advise me what resistance I should use for volume and balance control, as values are not indicated in the diagram.
Mike P
Old 10th December 2014, 08:34 PM   #2
please, help.....
Old 10th December 2014, 09:10 PM   #3
Is this problem the same with inputs disconnected? Is the input signal still audible otherwise?
This is a DC coupled (no isolating capacitors) input so any DC anomaly or disturbance at the source or in the wiring becomes a part of the input signal. Perhaps this is the source of the the crackling noise or if mistakes have been made in replacing the pot, there may be damage to the amplifier and exposed like that, it's very easy to do damage unawares.
If you fitted the stepped attenuator, it must surely have been selected to match the pot it replaced and pots of all brands have marked values, so this is not difficult.
Ian
Old 10th December 2014, 09:27 PM   #4
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
if attenuator is having same or lesser resistance as pot originally used , also made with make-before-brake switches , there can't be a problem
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 11th December 2014, 09:15 PM   #5
Thanks for replay and ideas.
When I got this Amplifier it came with volume and balance control swapped from resistors ladder, to normal pots (poor quality ones).
At the beggining I replaced those pots to resistors ladder (same value as pots), but it didn't rule out noise during changing volume.
Please have a look on that diagram I added; balance pot is in the feedback loop, rather than in series with pot.
Pot for volume control was 10k and ones for balnce-50k.
Balance was working very poorly; I assume that the value might me incorrect or wrong type pot was used (log instead linear or vice wersa).
I tried to get rid of balance pot, using 2x25k resistors, but it didn't resolve problem with craking noise.
I'd rather stick with the oryginal desing since MAS normally knows what they're doing.
Will it help if I make some PCB photos?
Old 11th December 2014, 09:51 PM   #6
mjf is offline mjf  Austria
can you measure if there is a volt drop (Vdc) across the vol pot (against ground)?
how big is the offset voltage (Vdc) at the output of the amp (without speaker load)?
Old 12th December 2014, 05:26 AM   #7
Originally Posted by krasnal View Post
......balance pot is in the feedback loop, rather than in series with pot....
The balance controls in the feedback loop are also at DC if there is any DC offset at the output, meaning they will interact if there is a problem at the input with DC signal, as well as if there is a problem in the amplifier.
Have you removed the input leads yet to check the effect?
Do you have a digital voltmeter to measure anything?
Can you link the schematic or increase the size of the image as it requires magnification. (too blurred to read though, even on a 24" screen).
Please reply or say whether you understand the questions or not.
Ian
Old 12th December 2014, 06:43 AM   #8
VaNarn is offline VaNarn  Australia
It appears that the problem may be caused by DC flowing through the volume control.To overcome this a 100 k ohm resistor should be connected to ground from the Q1 and Q3 bases ( the same for Q2,Q4) and a ,say, 10 microfarad film capacitor fitted between the wiper of the vol. pot. and the junction of R13/C1 (also R16/C2).The value that you choose for the vol. control is not critical, if all of the associated sources are of a low impedance.A value of 10 K ohm is normally o.k..What is needed,is a control that gives a broad transistion from silence to loud and this is usually via a log. scale.
Old 12th December 2014, 05:45 PM   #9
Thank you for your effort to help me with this hiccup. Ian, I do understand your suggestions. I will try check all ideas tonight and share findings. Thanks again,
MikeP
Old 12th December 2014, 11:21 PM   #10
I tried to add a bit more diagram than before. It's still new to me
Is DC offset a problem for a preamp volume control? andyr Analogue Source 18 23rd November 2013 04:42 AM
Volume Control Problem ExtraCredit1 Analog Line Level 2 11th August 2012 12:07 AM
Problem with DS1802 digital volume control IC some0ne Analog Line Level 18 18th April 2012 05:27 PM
Linn Intek Volume Control Problem Grainger Solid State 4 2nd October 2006 05:23 PM
volume control problem mozikluv Everything Else 3 8th September 2003 09:58 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
