Byrston 4B repair - diyAudio
Old 4th December 2014, 04:43 PM   #1
stefan11's Avatar
Default Byrston 4B repair
My brother asked if I would look at his very old Bryston 4B amp that is acting up.
Both channels work however, there is a large amount of white noise on one side. The other side is fine. When I opened the case I found a few resistors next to the output transistors on the white noise side rather burnt. I checked for grounds on that side and I have good ground continuity.
Looking for any quick ideas before I begin taking the suspect channel apart,
Thanks Stefan
Old 4th December 2014, 06:02 PM   #2
rayma is offline rayma  United States
Originally Posted by stefan11 View Post
My brother asked if I would look at his very old Bryston 4B amp that is acting up.Both channels work however,
Check the resistors' values first, they may be ok. These are probably the output stage's emitter resistors, which do burn power and can turn color without being bad.
If you're going to repair the amp, you may as well replace all the electrolytic capacitors, which have likely deteriorated.
Bryston 4B ST problem.....? Ebbertron Solid State 12 29th December 2010 01:37 AM
Help with Jensen LS-4B's... ptwining Multi-Way 0 8th May 2006 01:05 AM
FS: 2 Bryston 4b's dunderchief Swap Meet 1 14th October 2005 10:27 PM
idle current for bryston 4B Danielll Solid State 2 3rd October 2005 06:25 PM
Looking for a Bryston 4B ST clone Phil O.son Solid State 5 6th November 2002 09:36 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
