Hi, I have a HK990 and need to control/adjust bias settings.
Does anyone know how to do this (where to messaure and how) ?
The service manual is a little tricky to understand and this message http://www.diyaudio.com/forums/solid-state/244941-how-bias-hk990.html don't point out exactly how to do.
Best Regards
Best Regards
The alignment instructions are flawed. Look at the power amplifier schematic. That one pretty clearly calls for 38 mV between TP4 and TP6 (or TP3 and TP7, TP2 and TP6, or TP1 and TP5).
Thank you very very much for your reply
But do I have to messaure specific on the TP points ?
The TP points are very hard to get to (need to dissambly alot to get access) or is it good enough to messaure directly on the legs on the resistors who is sitting next to the TP points as shown in the service manual on page 109 ?
Best regards
