Cutoff frequency for RF rejection?
Old 2nd December 2014, 06:49 PM   #1
Fusion916 is offline Fusion916  United States
Default Cutoff frequency for RF rejection?
What -3db frequency do you guys use to suppress RF? 100MHz? Even lower?
Old 2nd December 2014, 07:05 PM   #2
Bone is offline Bone  United Kingdom
50kHz
Old 2nd December 2014, 07:24 PM   #3
rayma is offline rayma  United States
As much as the frequency, it matters also how the suppression is executed in the particular hardware.
Old 2nd December 2014, 07:30 PM   #4
RJM1 is offline RJM1  United States
Just my opinion, but I go about 300Khz to stay away from the 100KW AM transmitters ( 540 to 1700Khz). I had a problem in the 1970's with a CB radio (27Mhz) over comming my HK Citation I's phono preamp section only rated at 80Khz.
Old 3rd December 2014, 09:15 AM   #5
F-3dB between 100kHz and 300kHz, passive at the input.
I use ~700us for my passive RC.
regards Andrew T.
Old 3rd December 2014, 09:35 AM   #6
mcd99 is offline mcd99  United Kingdom
I use around 300kHz. 2nd order filter.
Old 3rd December 2014, 09:41 AM   #7
Might be worth mentioning that these "filters" attenuate the RF. They don't remove, nor eliminate it.
A filter eventually stops filtering at some highish frequency.
Two filters staggered by a couple of decades, may perform better than one "super filter".
regards Andrew T.
Old 3rd December 2014, 09:42 AM   #8
How do you implement your 2nd order filter?
What Q does it achieve?
Does it have any "ringing" as a result of 2pole characteristic?
I use a 47oF at the input socket and then my ~700us RC at the PCB.
Strictly this is a staggered frequency 2pole, or maybe a 3pole if cable inductance has a significant effect.
I don't know how to analyse it for Q, nor ringing.
regards Andrew T.
Old 3rd December 2014, 09:51 AM   #9
DF96 is offline DF96  England
Yes. Don't expect a filter to work from 50kHz to 2.4GHz.
Old 3rd December 2014, 01:50 PM   #10
wg_ski is offline wg_ski  United States
If you get enough MHz or whatever signal coming in, it can overload a stage and force it into nonlinearity. Then you hear the modulation signal. This could even happen in a power supply component (and your electrolytics are no good at these frequencies). The RF level required to do this may not even be very high as you don't have much if any distortion-reducing feedback at RF.
Cutoff frequency for RF rejection?Hide this!Advertise here!
Erse crossover cutoff frequency? rms1 Multi-Way 4 7th January 2013 04:42 AM
Frequency Cutoff habsrock93 Full Range 2 21st August 2007 02:32 PM
Crossover cutoff frequency ? Fradbut Multi-Way 3 22nd January 2007 10:31 AM
Gsm and RF rejection ... djdamix Solid State 5 13th October 2004 10:11 AM
Reasonable low frequency cutoff markkanof Multi-Way 5 12th June 2002 11:14 PM
