Kenwood KA-3020 Volume control - diyAudio
Old 2nd December 2014, 04:48 PM   #1
Gaz67 is offline Gaz67  United Kingdom
Default Kenwood KA-3020 Volume control
First of all I would like to say hello to everyone... I'm a Newbie
I have a 20+ year old Kenwood KA-3020 amplifier that is in need of a new volume control.
The shaft of the old one has sheared through and I have removed it from the board.
The number on the part is:
0651790-100K BX2 (ALPS)
I have tried searching for a similar part but so far had no success.
Can anyone help ?
Is this a bespoke part made by ALPS for Kenwood specifically for the KA-3020?
As far as I can tell the Amplifier is now useless without it
Old 2nd December 2014, 05:42 PM   #2
Kiriakos's Avatar
I have one KA-7020 and love it.
My advice would be to contact any known as Kenwood service points and seek there information.
Kenwood is no more regarding official support, but old service points could have info or old stock to offer.
ALPS by contract is bonded and not able selling you such parts.
Advanced work around is possible but only from a true expert with many years of experience.
Old 2nd December 2014, 06:31 PM   #3
east electronics's Avatar
Re Kiriakos ... pull it together re gamoto what are you talking about ???
Please allow a bit of Greek between the Greeks
There is absolutely no chance that you are going to be able to locate a part that was made by alps for kenwood a company that actually changed hands and strategic over 10 times the latest 10 -15 years .
Farther more this model exists i think before internet time so the chances that the parts are documented are very very low
I bet you that the part exists somewhere in the globe and also that some Luxman or JVC amplifier uses the exact same part but the one who has it don't know that it fits this Kenwood and a few other amplifiers
the chances that you are going to be able to locate it is low to zero
Only viable solution is to fit inside a standard 8 pin 100k blue line pot not an easy task since it will require hard wiring and possible mod to fit the knob
regards
Sakis
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 2nd December 2014, 06:50 PM   #4
rayma is offline rayma  United States
Originally Posted by Gaz67 View Post
I have a 20+ year old Kenwood KA-3020 amplifier that is in need of a new volume control. The number on the part is:
Kenwood KA-3020 Manual - Stereo Integrated Amplifier - HiFi Engine
This is a typical 100k stereo volume control with a loudness tap. The only question is the mechanical fit.
It could be hard wired to the pcb since the two sets of terminals are on opposite sides of the control.
Radio Shack has an Alps that is very close, other than the terminal placement. The knob may even fit properly.
100K Dual-Ganged Stereo Volume Control - RadioShack.com
Old 2nd December 2014, 07:09 PM   #5
As rayma says, you should be able to make something else fit - even if it looks a little messy - the Radio Shack one looks pretty close though.
After the demise of Kenwood in the UK the spares distribution was taken over by a third party - but we never dealt with them, and I can't even remember who they were (and it's unlikely they still supply spares).
Nigel Goodwin
Old 2nd December 2014, 10:12 PM   #6
Thanks to all for the replies (including the between the lines Greek bits ) ;-)
That's some great info, I now know what I'm looking for.
The Radioshack component looks a good replacement, with a little wiring to the board and a bit of filing etc it might well fit :-)
Is there a Radioshack based in the UK ? Or is Maplin my closest alternative ?
Old 3rd December 2014, 07:22 PM   #7
Oh Well, Maplin doesn't have anything suitable and Radioshack doesn't seem to ship to the UK.
I'll keep searching.
Old 3rd December 2014, 07:36 PM   #8
found this one
Stereo Volume Control - Potentiometers and Trimmers | T2 Retail
seem to be the Radioshack item..... but out of stock
one question
The radioshack item is audio taper.
Is the original control Linear or audio taper ?
Old 3rd December 2014, 07:45 PM   #9
Mooly's Avatar
The original is almost certainly a log type (so yes, an audio taper). All that means is that the output vs rotation angle is not linear but follows a more logarithmic law. Log or lin, either will work as volume control, the only difference is the "feel" of the level of sound with rotation angle.
What is wrong with the original ? Is it crackly and noisy ? If so then it looks as though it could be possible to open it all up by bending the tabs.
Installing and using LTspice. From beginner to advanced.
Old 3rd December 2014, 08:07 PM   #10
As Mooly says, volume controls are log (sometimes called audio taper).
However, you can make a linear one 'near enough':
Potentiometers (Beginners' Guide to Pots)
Nigel Goodwin
Kenwood Ka-2600 Kermit100 Solid State 4 23rd April 2014 02:10 PM
Kenwood KA-405 Karl vd Berg Solid State 71 22nd May 2013 05:12 PM
nad 3020 volume control reddish75 Solid State 3 9th June 2011 02:07 PM
Help with Kenwood KA-94 lumstar Solid State 0 7th January 2009 01:31 AM
Kenwood Ka-770b dexter2003 Solid State 7 3rd July 2008 06:22 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
