Comparing FFT of Two Amplifiers - diyAudio
Old 30th November 2014, 06:36 PM   #1
Jay is offline Jay  Indonesia
Default Comparing FFT of Two Amplifiers
First, we cannot judge an amp from FFT alone (in fact, I don't want to tell detailed differences from other criteria). But still, I want to hear what you can see in an FFT alone (i.e. which one do you prefer: A or B).
So no more information other than the image showing FFT of two amplifiers. Each with 1W, 5W and 40W FFT.
I haven't built the two amplifiers, but is in the soldering process for amp B and drawing and transistor matching process for amp A.
Old 30th November 2014, 09:06 PM   #2
fonon is offline fonon  Poland
FFT spectrum should be presented with linear frequency scale due to linear sampling in frequency domain. Regardless, the harmonics are better visible in linear scale. When you show FFT spectrum, the parameters of analysis must be specified (number of samples in record, window function, etc.). The data outside dynamic range of analysis aren't valid.
f.
Old 30th November 2014, 09:29 PM   #3
SY's Avatar
You do understand that "FFT" is a mathematical operation, not a measurement technique? I think what you mean here is "single frequency distortion spectrum."
You have vastly too little information to make any sort of intelligent judgment. Frequency response, distortion, noise, source impedance, stability. That's your basic measurement set, and yes, you can use FT techniques to measure all of them, once you actually have some real amps to compare.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 30th November 2014, 09:57 PM   #4
6L6 is online now 6L6  United States
6L6's Avatar
I agree with SY - build your amps and measure them equally, then present the FFT for viewing. Until then, it's just pretty pictures.
Also, if you haven't built the amps, where did you get the FFT that you posted?
Old 30th November 2014, 10:46 PM   #5
Not exactly. FFT is mathematical operation used as measurement technique. It's a kind of transformational methods of spectral analysis (in technical classification).
Type 7770 - FFT Analysis - Type 7770 - Brel & Kjr
f.
Old 30th November 2014, 10:47 PM   #6
6L6's Avatar
A fast Fourier transform (FFT) is an algorithm to compute the discrete Fourier transform (DFT) and its inverse. Fourier analysis converts time (or space) to frequency and vice versa; an FFT rapidly computes such transformations by factorizing the DFT matrix into a product of sparse (mostly zero) factors.[1] As a result, fast Fourier transforms are widely used for many applications in engineering, science, and mathematics. The basic ideas were popularized in 1965, but some FFTs had been previously known as early as 1805. Fast Fourier transforms have been described as "the most important numerical algorithm [s] of our lifetime".[2]
Old 30th November 2014, 11:31 PM   #7
SY's Avatar
Originally Posted by fonon View Post
Not exactly.
Yes, exactly. You are conflating different concepts- an FT is a mathematical transformation of data gathered in a measurement- no matter what the measurement. FFT is a particular algorithm used for the calculation.
@Jay: Build two amps, generate frequency response, distortion spectra at various frequencies and power levels, source impedance versus frequency (at different levels if you're dealing with a poor design), noise, and stability. Use FT techniques on the data if you like. Try all this with a few different loads, including speakers.
Then you can start talking about making valid comparisons.
Old 30th November 2014, 11:34 PM   #8
I guess the more information doesn't mean the more informed decision? For example if there were 10 criteria, amp-A excels in 4 criteria and amp-B excels in 6 criteria, doesn't mean that amp-B is better.
Of course, I know you are right that technically the information is insufficient and that there's a necessity to build both amps (which I will). It's like I'm sure both will work (which it might not ) and I'm guessing their quality from FFT alone to choose which one to build (I regard other criteria, even tho different for both amps, are equally acceptable).
If I have built the amps, I will have no questions as I know how they both sound.
Simulation of course?
Is it not visible (the harmonics) in this windowing? The "exact numbers" are not valid, I know, but subjective comparison is I believe valid.
Assuming that parts and power supply will be cost no object (the amps were simulated without the PS), I believe amp-B will have more details. But look at second order harmonic domination (and absence of higher order harmonics) in amp-A for example. In my experience, such simulated performance is always telling the truth.
Old 30th November 2014, 11:42 PM   #9
6L6's Avatar
... In my experience, such simulated performance is always telling the truth.
I am a Professional Learjet Captian by trade. I can tell you all about simulation. (And the fact that the sims cost usually 3X the price of the airplane...)
Simulation, although useful, ain't the real thing.
Old 30th November 2014, 11:53 PM   #10
vzaichenko's Avatar
Send a message via Skype™ to vzaichenko
Hi Jay, the "A" spectrum looks more like the one for VFA, the "B" spectrum looks like CFA one. In general, the less harmonic components are visible - the better. Also, having 3-rd harmonic significantly lower than the 2-nd one, and then just a little bit of 4-th and that's it - a very good profile. The "B" spectrum looks much more "nervous", but it doesn't automatically mean the amp "B" is bad. It may have other benefits - better slew rate, square wave and phase responses...
Valery
If you can't explain it simply, you don't understand it well enough (c) Albert Einstein
See my projects at VIRTUAL ZERO distortion AUDIO
comparing various Alpair's Bob Brines Full Range 36 25th September 2015 08:35 PM
Comparing drivers ziocalepino Full Range 13 17th March 2011 09:17 AM
Comparing Bose(o) Chip Amps 5 29th July 2005 10:19 PM
Comparing sensitivities Grahamt Multi-Way 2 20th September 2004 07:42 PM
Comparing GC's yuval Chip Amps 20 10th June 2004 06:26 PM
Copyright 1999-2017 diyAudio
