Why this amp does not function ?????
Old 21st January 2004, 07:30 PM   #1
PicancoNet is offline PicancoNet  Brazil
Send a message via ICQ to PicancoNet Send a message via MSN to PicancoNet
Question Why this amp does not function ?????
Hello, when i use 2 bipolar transistors (TIP41 and TIP42) in class
b configuration, the amp function.
when i use 2 bipolar darlington transistors (TIP142 and TIP147) in class b configuration, the amp not function. Why ????
Sounds Goods
Old 21st January 2004, 09:14 PM   #2
bigparsnip is offline bigparsnip  United Kingdom
bigparsnip's Avatar
you will need to put some bias resistors in before the base of the transisorts, otherwise there will be no current to flow through the base to create any drive. Try again with two 1k resistors in the circuit, going (one each) from the right hand side of the first capacitor, to the power rails.
Old 21st January 2004, 11:04 PM   #3
azira is offline azira  United States
You don't HAVE to bias the transistors on in order for it to work. It will lower distortion if you DO but you don't need to if you just want to see it work.
The reason it doesn't work is that your basic bipolars only have 1-vbe drop from base to the load. That means your crossover "zone" is +0.7 - -0.7 or 1.4 volts. With the darlingtons, you have 2-vbe's on either end. So this is +1.4 - -1.4 volts, or 2.8 volts of dead zone. This is probably a pretty significant portion of your signal if you're driving it with an opamp with low supply rails. What are your supply rails and what kind of opamp are you using?
Do this to get it to work on your darlington version. Put a 1k resistor in series with 4 diodes (all in seried) in series with a 1k between your +vcc and -vee. Apply the signal halfway between the diodes.
To Tip 142 To Tip 147
+Vcc +---/\/\/\/-+--|>|--|>|--+--|>|--|>|--+-/\/\/\/--- -Vee
Signal In
you'll sort of have to turn this picture on it's side to see it right...
This is not a permanant fix!!! It's just a first step. With any real voltage rails, you'll cause thermal runaway when the devices heat up. This will be enough to get it running though.
Danny
Old 21st January 2004, 11:11 PM   #4
Richard C is offline Richard C  United Kingdom
You could also get rid of the 1uF caps and include the transistors within the NFB loop and add emitter resistors.
Old 22nd January 2004, 12:51 PM   #5
Signal In
Danny
I'm using LM386
Sounds Goods
Old 22nd January 2004, 03:57 PM   #6
PicancoNet,
the best thing to do is provide your complete schematic with component labels and values, otherwise this could be very hard work.
Also, look at the schematics of other amplifiers and see how it should be done.
Old 22nd January 2004, 04:13 PM   #7
Originally posted by Richard C
PicancoNet,
The complete schematic is above:
Sounds Goods
Old 22nd January 2004, 05:15 PM   #8
Since he's got a 30V supply on the outputs, I have a feeling the LM386 is running on a seperate supply because it can't handle 30Volts of rail. The cap is probably to AC couple the output of the Op amp onto the output trannys. He would have to AC couple the NFB back to the op amp, but I bet in the actual circuit, he's got the NFB coming from the opamp which means the xover distortion is fully present. His darlington version probably really sounds like crap.
P:
I don't think that'll win anything to have the driver on different rails than your output since your output will only be as high as your driver will push.
Old 23rd January 2004, 11:54 AM   #9
P:
Im using 15V for the LM386.
Sounds Goods
Old 23rd January 2004, 04:20 PM   #10
That's the point, your output stage won't be able to deliver a higher voltage than the input stage so why run it on 30V at all.
I can't see any merit in the approach you've taken even if it was made to work it wouldn't be very good.
All the answers can be found here
http://sound.westhost.com/amp-basics.htm
Why this amp does not function ?????Hide this!Advertise here!
Function Generator? TheDriver Parts 4 18th August 2008 10:46 AM
Looking for an used function generator Eva Swap Meet 0 21st February 2008 07:56 AM
Amp Will Not Function prorms Solid State 16 2nd December 2006 09:26 PM
What's the function of this? stef1777 Analog Line Level 5 21st March 2006 12:16 PM
Copyright ©1999-2017 diyAudio
