diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   AIR-Core Vs Ferrite-Core Inductor in Class-D amplifiers (http://www.diyaudio.com/forums/solid-state/26498-air-core-vs-ferrite-core-inductor-class-amplifiers.html)
Workhorse 21st January 2004 06:55 AM
Recently i look around several class-d amps which used air-core as well as ferrite core inductors at their outputs to suppress switching frequency component.
AS I am working on class-D amp project , Kindly Help me which filter should i use for suppressing switching frequency components and best performance in terms of sonic quality.:)
phase_accurate 21st January 2004 07:51 AM
Why don't you use something inbetween ? A ferrite-core with an air-gap.
Charles
Workhorse 21st January 2004 08:13 AM
Commentable Thoughts
Hello Charles, I dont able to understand what is meant by A ferrite-core with an air-gap.
PLZ Clarify.
amp_man_1
phase_accurate 21st January 2004 09:32 AM
Have a look at this one:
http://www.lcaudio.dk/com/zpn10.jpg
(Hi Lars ! ;) )
The result is less core-saturation but also a lower AL value than the original core-set. But you still need less turns than a similarily sized air-core coil would need. Another advantage is that there is less EMC problems than using air-core coils.
I once thought about using a toroid-shaped "air" core. But that one would need much more windings than a cylindrical coil.
Someone else (on this forum, but I don't remember who it was)proposed two coils beneath each other connected in a way that they are cancelling out the stray field (in fact a cylindrical coil that is bent at half it's length). This could be a good compromise either.
Charles
Workhorse 21st January 2004 10:48 AM
SIR I DONT have access to ferrite cores right now, can u PLZ tell me that what are the disadvantages air core inductors and how can i calculate the number of turns for a given inductance and area of a core, can u plz tell me some formula to calculate it.
ukram 21st January 2004 11:03 AM
I'm going to use air core inductors in my amp, since it seems to be really easy and cheap to make them. How to measure or calculate the EMC? For example, how much di/dt is ok? I guess using as big coil as possible makes current changes small?
phase_accurate 21st January 2004 11:17 AM
Are you talking about the OUTPUT-FILTER inductor ?
If so, the peak current in the inductor at idle is:
carrier_peak_voltage / (2 * carrier_frequency * inductance)
Please keep in mind that this current is reactive and is only causing some conduction losses in the output stages, while too large a coil would lead to a low filter cutoff frequency.
Charles
subwo1 21st January 2004 05:14 PM
Hi Charles
Hi Charles, thanks for remembering this idea.;) Sometimes I rather stumble onto different things.
Amp_man, what I do is just try differing numbers of turns until the performance is optimized. But a ball park figure may be about 20uH for 30 turns on a 1" form for an air core choke. Using that as a reference, the inductance is proprtional to the square of the number of turns.
ukram 21st January 2004 09:01 PM
Yes, meant output filter. Another thing to worry is the speaker capacitance, how much can it be? I think someone mentioned "isolation", probably meaning yet another inductor after output filter to isolate speaker from feedback loop. Is this really necessary?
phase_accurate 22nd January 2004 06:14 AM
That depends on your feedback topology, i.e. whether you are going to take-off feedback before or after the output filter AND wheter you are using a self-oscillating topology.
Charles
Resources saved on this page: MySQL 18.75%
