Wharfedale Linton amp, shut down problems. - diyAudio
Old 16th November 2014, 04:15 PM   #1
Default Wharfedale Linton amp, shut down problems.
Apparently its a leak delta 70 in disguise.
Anyhow, when I shut it down it sounds like a sipper being undone, it starts as a low tone then gets high pitched before fading out, this is only in the left channel, there is a bit of a thud from the right but its not really too bad.
The thing has been in an attic for many years.
The problem happens on all source selections and is not volume dependant.
When working it seems to work fine, Just this noise as soon as I switch it off.
Any ideas?
The manual for the Leak Delta 70 is here in HIFIEngine. I have read that the leak and wharfedale amps are identical.
Login - HiFi Engine
Old 16th November 2014, 04:26 PM   #2
Mooly's Avatar
First things that come to mind are dried out electrolytic caps. Something of this age should really be rebuilt with new replacements.
Thuds and noises on switch on and switch off are "normal" with any capacitor coupled amp that doesn't employ a dedicated relay to give a speaker delay when powering up.
So I suspect yours is a little worse than normal given the age and probability of cap issues, but you will probably never get it silent.
Old 16th November 2014, 04:30 PM   #3
So pulling the power and pre boards and rebuilding with new caps might sort the problem?
Would these old amps use film caps?
Old 16th November 2014, 04:52 PM   #4
No, they use electrolytics - but the larger ones aren't fitted on the boards.
As it's only on the left channel, try swapping the left and right boards over, and confirm the fault swaps channels (proving if it's on the board or no).
Nigel Goodwin
Old 16th November 2014, 04:59 PM   #5
Mooly's Avatar
Film caps if used would tend to be small values. You would need to look and make a quick evaluation of what is fitted. I'm guessing these are all "axial" caps where a lead comes from each end of the cap rather than more modern radials which have both leads together at the same end of the cap. It no big deal, just check physical sizes of things before ordering, modern caps will be tiny in comparison. Axials are still available but tend to be dearer and available in limited values and ratings.
The fact the volume control has no effect means the problem is specific to that one channels power amplifier.
Old 16th November 2014, 05:04 PM   #6
This might be quicker for reference as the above link needs amendment. It comes by way of Paul Kemble's excellent site for vintage UK audio reference.
A Paul Kemble web page - index to 'sound' webpages.
Ian
Old 16th November 2014, 05:10 PM   #7
Mooly's Avatar
Its one of those links
Old 16th November 2014, 05:36 PM   #8
Hmm...you mean my link Mooly? Perhaps that part of of the spam doesn't travel to Oz as I can log in on another PC also, without getting that sort of message but of course, Angelfire is a massive spam generator - I guess they keep only the best for the the home crowd!
This link should divert people to the registration process which may be needed at Hifiengine. Apolgies to any who suffered that link's problems.
Leak Stereo 70 Manual - Stereo Integrated Amplifier - HiFi Engine
Ian
Old 16th November 2014, 06:34 PM   #9
Mooly's Avatar
Err... yes lol Picture hosting and file sharing sites have the same problem. I always use task manager to close IE if anything like pops ups.
Old 16th November 2014, 06:41 PM   #10
That's very odd guys, I switched the two power amp boards, left to right and right to left and the problem is now gone, all I have now is a noisy volume/power switch.
I wonder if it was dirty contacts on the board or the socket it locates into?
Anyhow, I did notice the power on bulb was hunting slightly however this also seems to have got better with a few on and off cycles, I wonder if the thing just needs a good clean?
What do you guys recommend to clean and lubricate dirty old pots and switches?
Odd Wharfedale Linton XP2 (variation?) Crossover Help Phase700B Multi-Way 4 16th February 2014 11:23 PM
wharfedale pm 600 problems findingemo Solid State 1 25th March 2012 07:53 PM
FS wharfedale linton 3 vintage speakers v4lve lover Swap Meet 1 22nd September 2011 02:17 PM
Wharfedale Linton 3XP speaker wiring guitarman1 Parts 4 15th October 2008 06:49 AM
PE Bash 500 Amps shut down problems? crippledchicken Subwoofers 2 6th August 2007 12:29 PM
Copyright 1999-2017 diyAudio
