Altec 1593B bias issue - diyAudio
Old 10th November 2014, 03:40 AM   #1
mazur is offline mazur  United States
Default Altec 1593B bias issue
Hi.
I'm having a real strange issue with my Altec 1593B. I have 2 amps, one sounds great but the other has no bias on the power transistors at all. At very low volumes the sound is distorted, as expected, but as the volume is turned up the transistors are biased and starts to sound better and at loud volume sounds fine, since the bias gets to the operating point.
I have attached the schematic. Here is what I've done so far:
- both circuit boards (the part on the schematic surrounded by the dotted lines) work on the good amp. But neither work on the bad amp. So it's definitely not the board.
- with no signal, on the bad amp, the base to ground voltage of Q1 and Q3 are around .5V as expected from the circuit. But the emitter to ground voltage which should be around 30mV is zero.
- I tested all transistors and they are all fine. Still, I replaced all transistors with a new set and still the same. I also replaced the zener CR5 for the 15V line and the diodes CR2 and CR3.
- all collector voltages are fine at 31V, the OPT looks OK and it's probably OK since it plays fine at loud volumes. The stabistor measure 1.3V as expected. The power resistors measure fine and are not open.
- I re-soldered all connections from the circuit board connector and the connections on the power transistors.
Don't know what I'm missing here. Any help is appreciated.
Thanks.
Elias
Old 10th November 2014, 03:45 AM   #2
rayma is offline rayma  United States
Originally Posted by mazur View Post
Hi.
How about the double diode CR1? This may be bad, or its connection to the circuit. If both transistors of the pair are no bias, it must be something that affects
both sides of the circuit the same, symmetrically.
Old 10th November 2014, 03:13 PM   #3
I thought about that as well, but the voltage drop on the CR1 is 1.3V as shown in the schematic and the voltage in the connector is 1.3V as well. Also, the forward bias voltage out of the board is .5V on both sides. I checked continuity and it looks fine.
What is really strange is that the voltage on both bases are .5V as per schematic, but the emitter in on 0V.
Elias
Old 10th November 2014, 03:31 PM   #4
Send a message via Skype™ to JonSnell Electronic
Have you checked the bias voltage resistors, R124/125 and R7?
www.flyingmole.co.uk For World Wide support for Flying Mole, Class D, Refurbishment and Repairs. www.jonsnell.co.uk
Old 10th November 2014, 03:34 PM   #5
Elias
The 0.5V is applied as a bias voltage, so it's not the result of current flowing in the output transistors.
Can you ohm the connections from the emitters of Q1,2,3,4 to ground? It seems like there's an open connection there.
Old 10th November 2014, 04:38 PM   #6
Yes. R124/125 is in the circuit board so I know it works, also because the bias is reaching the base of Q1 and Q3. I checked R7 and it tests fine.
Zener diode on Altec 1593B amp mazur Solid State 0 26th October 2014 04:46 AM
Possible Bias issue?? JRGuitarGuy Instruments and Amps 20 9th November 2012 01:47 AM
Cyrus One Bias Issue pampalini Solid State 35 1st May 2012 11:45 AM
Weird F5 bias issue JZatopa Pass Labs 20 25th June 2011 04:37 AM
Yamaha M-60 bias issue FootFungus Solid State 0 12th May 2009 12:36 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
