Problems with Boston gt-24 car amp
Old 7th November 2014, 03:03 PM   #1
Leland331 is offline Leland331
Default Problems with Boston gt-24 car amp
This is what happened.
I received my order with the new power supply fets, diodes, and resistors and put them them in (I carefully used the tip of a soldering gun that I made flat and sharp). Initially, the amp would just blow fuses and I found some bad fets.
I went to power the amp up on low voltage and it seemed okay so far so I went to the full 12 and one of the new power supply fets heated up and part of the package flew across the room. The resistor in series with the gate was burned as well.
Later on, I thought I would try diagnose why that happened and curiously applied power with the blown fet removed while carefully monitoring the temps. Well the amp started up and seemed to run absolutely fine and played music pretty well.
I then took an old fet that didn't seem shorted and held it in place.. It buzzed and heated up very hot very quickly and drew a load of current. I grabbed another old one (I dont know if it's good or not or how to really test that) and held it in place and well with not really any noticable difference, the amp kept running and no overheating or excessive current draw.
I don't really know if maybe I just got a bad new fet or what really happened so I was hoping that somebody could explain what they think... Also, should I just put in an old fet that seems to work? Or is it possible that it'll be really weak or something and that it would be worthwhile to pay for shipping another and waiting for it?
Problems with Boston gt-24 car ampHide this!Advertise here!
Boston Acoustics GT-28 In Protect mklry Car Audio 6 9th January 2013 08:36 PM
Boston GT 50 ian33 Car Audio 23 10th October 2012 09:43 AM
Boston Acoustics GT-40 mike49504 Car Audio 20 7th October 2011 02:20 PM
Boston GT-42, info needed FireII Car Audio 15 31st August 2010 12:52 AM
>>> cheap 50,000uF 60V capacitors here >>> Lubomir Swap Meet 0 1st February 2007 03:36 PM
Copyright ©1999-2017 diyAudio
