Vintage Receivers for BiAmping F.A.S.T setup - diyAudio
Old 7th November 2014, 07:09 AM   #1
Default Vintage Receivers for BiAmping F.A.S.T setup
Vintage Sansui and Marantz 2252 for bi amping?
Hi guys, I have a vintage Sansui AUD607G that gives out 60wpc in 8ohms and a Marantz 2252B that gives out 50wpc in 8 ohms.
Both of them have pre-outs and main ins.
I'm building a Full range Open Baffle Speaker with an Audionirvana 6.5" and I'm currently mulling over adding a helper woofer (8" or 10" driver) in an enclosure.
Active crossover will be managed via a MiniDSP 2x4 unit for any room and eq issues.
Got a few questions though:
1.) Can I use these vintage receivers as a preamp for the MiniDSP and for bi-amping the FR and the helper woofer?
I'll be using the Sansui Preamp outs > Mini DSP in > Amp Main ins.
I'm thinking Sansui > Low Woofers and Marantz > Full Range Speaks
2.) Will I need a separate passive attenuator or volume control in between the MiniDSP outs and the Main Ins of the amplifiers? If yes, got any cheap recos for these?
3.) Any things I should watch out for?
Thanks!
Old 7th November 2014, 07:34 AM   #2
picowallspeaker's Avatar
The aberrations introduced by the double AD/DA conversion !?!?
Question: doesn't the DSP allow to control the level ?
OH! It must be that loss of dynamic due to the bit reduction (or something like that ) a.k.a. resolution.
Maybe... the AN can stand the power on the very bass notes though it could not reproduce them, so just a passive line level crossover > change the input cap of the amp driving the AN( from 0.01 to 0.1 uF )
and develop a stereo low pass with a quad IC such a TL 074. Little "trimmers" or vol. pots allow for fine level adjustements and once you set the right levels & gain stages you'll just need the master volume control of your preamp.
Old 7th November 2014, 07:53 AM   #3
Thanks for the reply.
Its just for a secondary setup so I not much critical listening will be done and audio levels are quite low, just got an itch to scratch to use the miniDSP and want to experience it via a MiniDsp 2x4. At its price, its inexpensive enough to allow experimenting.
I'm also leaning on just using dual active subwoofers if this bi amping thing is too tedious.
Old 12th November 2014, 02:50 AM   #4
Bump
Hidden audio setup in vintage car scourtaud Car Audio 7 15th June 2013 03:00 PM
LEDs in vintage receivers srinath Solid State 20 11th February 2013 01:23 PM
Anyone Collect Vintage Receivers? VintageReceiver Everything Else 0 7th November 2010 01:57 AM
FS: Transformer for vintage Pioneer receivers maurycy Swap Meet 2 26th August 2010 02:43 AM
Biamping for tontos Raka Chip Amps 12 22nd August 2003 12:09 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
