Rules about running cables? - diyAudio
Old 6th November 2014, 09:09 PM   #1
Default Rules about running cables?
So I understand that the AC power cables should be twisted together.
But what about the inputs coming from RCA plugs and speakers outs?
Do I need to keep them both away from power cables inside the amplifier??
Thanks.
Old 6th November 2014, 09:11 PM   #2
freax's Avatar
I'll give credit where credit is due. I learnt from Scott17 (on here) to route my audio lines close to the chassis and hug the wall of it, if the preamp circuit is at the front of the chassis then it should be routed like this to meet it there.
The power lines then should be correspondingly on the opposite side at which the low line level cables are routed.
So if you have a rectangular case, the power cables are on the left and the audio lines are on the right. and both hug the walls.
He used those little white clip things with glue on one side and a clip on the other to hold the cables up against the wall.
https://imgur.com/a/Cg1KM
https://i.imgur.com/LYdnDbF.jpg
KT88 SE Basic or Master Kit
diyaudio is against your rights. I do not have the right to be forgotten and after asking the issue has been ignored, therefore I'm leaving (peacefully) for this reason. I stand up for my rights. So long and thanks for all the Fish
Old 7th November 2014, 11:28 AM   #3
DF96 is offline DF96  England
Inputs should be screened or twisted, depending on whether you expect the main problem to come from electric fields or magnetic fields. In either case, keep well away from power wiring. Routing in chassis corners is good.
Gotham interconnect cables, speaker cables and coaxial cable Musik007 Twin Audio 24 23rd August 2013 04:57 PM
What advantages running ported midbass if you are running a sub? mitchyz250f Multi-Way 3 20th May 2008 02:34 PM
Audio, cables, and the ear-new science-the rules change KBK Everything Else 4 23rd October 2007 01:46 AM
ssabripo's DIY Interconnect cables: $200 cables for 1/10 th the cost! ssabripo Everything Else 3 26th October 2006 02:33 PM
running 11 speaker cables and 6 interconnects next to each other through a narrow spa rick57 Multi-Way 14 17th February 2006 11:35 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
