How to build a 21st century protection board
Old 22nd October 2017, 12:39 PM   #1571
jwilhelm is offline jwilhelm  Canada
Thanks Thimios.
I've written a basic protocol I plan to use for the first test.
0000 - off
0001 - tube preheat
0010 - 1st supply inrush
0011 - second supply inrush
0100 - power on
0101 - speakers on
0111 -
1000 - DC Offset
1001 - overload
1010 - AC Failure
1011 - overtemp 1
1100 - overtemp 2
1101 -
1110 -
1111 -
This would be simple to read with a port expander.
https://www.vzaudio.com/
Old 22nd October 2017, 01:22 PM   #1572
vzaichenko is offline vzaichenko  Russian Federation
vzaichenko's Avatar
For the same purpose, I've started experimenting with a tiny front-panel module, incorporating a 32-bit processor, OLED display, WiFi module and some input/output pins. Beer bottle cap is placed nearby as a scale - the board is really compact, worth $10 USD.
My first test sketch does the following:
1) Connects to the internet via local WiFi;
2) Communicates with NTP server, receiving the packet;
3) Syncs its internal clock with NTP time from the packet;
4) Calculates the timezone and shows correct time on the display, updating it once in a second.
The thing is very fast and versatile, so now we will likely start using it for indicating the soft-start sequence phases, error codes, heatsink temperatures, as well as logging telemetry at the web portal.
We're moving deeper into the 21-st century guys
If you can't explain it simply, you don't understand it well enough (c) Albert Einstein
https://vzaudio.com/
Old 22nd October 2017, 01:29 PM   #1573
thimios is online now thimios  Greece
Hi Valery,i'm sure that you can move deeper,your application engineer Jeff is the right person in the right position!
Old 9th November 2017, 09:34 PM   #1574
Amp control 6.01 is ready to power up. This one has connections for data logging. Let the fun begin!
Old 10th November 2017, 05:27 AM   #1575
Many projects at the same time!
Perfect!
How to build a 21st century protection boardHide this!Advertise here!
DIY build of the Pioneer C-21 preamplifier rjm Analog Line Level 48 10th July 2013 01:27 PM
Mystery ST-70 Driver Board Pyre Tubes / Valves 39 23rd May 2011 02:53 AM
Yet another Dyna ST-70 Input Board stokessd Tubes / Valves 6 3rd July 2010 11:14 PM
OLC "Slow Century" Anyone build? screamersusa Instruments and Amps 0 3rd June 2009 05:03 PM
Bringing the covox into the 21 century Mikael Abdellah Digital Source 5 3rd March 2008 10:33 AM
