Messing about with JFET input JLH - diyAudio
Old 29th October 2014, 04:02 PM   #1
Shoog's Avatar
Default Messing about with JFET input JLH
I have been messing with the idea of building a JLH with a Jfet input. This is what I came up with. I am only planning on a low powered version so +/-12V at 1A bias is OK. Seems to measure OK.
If I build it I will be using some 2SD718's rather than the 2N3055, which have twice the gain and a much higher Ft at 15mhz and hence the base stoppers to attempt to suppress instability. Couldn't find a suitable spice model so ran with the 2N3055's.
Seems the response is very much SE rather than PP with the bottom output transistor doing about half as much work again as the top one, and the current delivery far more typical of SE than PP.
Anyone care to critique.
Shoog
Old 29th October 2014, 05:45 PM   #2
knutn is offline knutn  Norway
There is a thread with all-FET versions:
All FET JLH Class A
Old 29th October 2014, 10:07 PM   #3
Bigun is offline Bigun  Canada
Bigun's Avatar
Shoog - I like it, no criticisms, just build it
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 29th October 2014, 11:35 PM   #4
JLH bottom has to work harder because the base current gets dumped into a rail rather than the load.
Nothing you can do about it but use complimentary devices or insulated gates, I suggest neither.
Simply with higher gain output devices, the work imbalance is a lesser fraction.
I prefer the sum of output currents be measured by the sum of voltage drops across sense resistors,
one to either side of the output rail. Set the bias current purposely a little too high. When the voltage
drops (in the sensing totem) sum to 0.7V, a shunt transistor (across the bias) bleeds off the excess.
The output class is forced to behave by strict Class A rule of linear emitter current vs linear collector
current, even though drive current requirements for each transistor's position in the circuit will differ.
Big advantage over the standard biasing scheme: its automatic, and it can't thermally run away...
Its good that yours has less than unity bootstrap. Not by itself in any real danger of becoming positive
feedback, but bootstrap too close to unity here can make the upper half less stable for something else
to tip it into oscillation. I used to do that part wrong and cause myself all sort of troubles.
Whats the purpose of r8?
Old 29th October 2014, 11:41 PM   #5
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
Subscribed
/U.
DIY projects blog
Old 30th October 2014, 10:01 AM   #6
Shoog's Avatar
R8 is simply a carry over from the original schematic - used to sense bias current. I can probably drop it. R10 will be variable and will be the bias adjustment.
Will think about other suggestions. Kenpeter maybe you could sketch what you mean by a bias transistor as I am having a little trouble conceptualizing it.
Took me a bit to work out what each component does, clever little circuit the original JLH.
Shoog
Old 14th December 2014, 11:18 PM   #7
Shoog's Avatar
So I haven't forgotten this project, but I have been messing about with making it a PNP version because i have more 2SJ170 and should get better matches than for the K74's.
When reading the schematic notice that it is effectively upside down in terms of the voltage sources.
The overall distortion is lower than the original, but the profile is not quite so benign.
Hopefully will start building this in the next few weeks.
Shoog
File Type: png Screenshot from 2014-12-14 23:16:00.png (26.4 KB, 113 views)
Old 12th January 2015, 06:08 PM   #8
Shoog's Avatar
Listening to a single channel as I type. Sounding quite good.
When I first built it and put it on to extended test I was getting 300mV of drift at the output over one hour. I decided this was unacceptable and so put in a simple OPAMP DC Servo (ala Broskie) which has meant that the bias is absolutely stable now.
I have put in simple zener series regulators with just 10V of reference - giving me final rails of 9.3V. This is OK for me as all i need this amp to do is deliver 3watts of reasonably clean power. However with such low rails I am finding it nearly impossible to set the output quiescent at anything more than 720mA, giving me a peak current delivery of 980mA and an output power of just under 4watts total output. This is OK since my heatsinks are a little marginal. The circuit is so stripped down at this stage that there are very few options to adjust the operating points and so it seems that is what I will have to live with.
Will be building it into a final case soon and introducing it to my vintage German speakers, I hope it remains well behaved. Will be adding a speaker protection circuit just to make certain.
Shoog
Old 19th January 2015, 07:38 PM   #9
Shoog's Avatar
Finally got this to a stage where i could put it on the main system. Hum is present at about 2.5mV amplitude which is to high for my speakers. Will probably put in another filter stage before my simple regulators.
After adding a prefilter to my DC servo I have a very tiny amount of oscillation but the sound is clean and clear. A little bit to much gain to match my system at the moment so cannot make a fair comparison to my other amps yet (I have an active subwoofer which is lagging behind a bit), will pad down the input at some stage.
First impressions are very positive, clean, clear and detailed, with an overall smooth presentation. probably the equal of my Le Monstre.
Shoog
Old 19th January 2015, 08:41 PM   #10
Bigun's Avatar
Nice!
I assume you measured the hum at the output - what kind of ripple voltage do you get on the power rails ?
Complementary JFET-JFET cascode input, BJT VAS-Drivers, Lateral Output Neutrality Solid State 53 23rd October 2011 07:53 PM
FS: PreAmp with Complimentary JFET Diff input & JFET ouput USAcircuits Vendor's Bazaar 12 21st June 2011 12:02 PM
CFP input for JLH amplifier Stee Solid State 1 13th February 2011 01:53 AM
JLH with a differential input stage mohan72 Solid State 46 10th September 2008 08:59 PM
JLH input impedance hlyytine Solid State 12 1st February 2004 08:00 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
