Help - diyAudio
Old 24th October 2014, 06:03 AM   #1
Shelah is offline Shelah  Zambia
Default Help
hello all.
am planing to make this amp. i have a 82-41-0-41-82 with 15v and
19v toroid trafo weighing about 9.5 kg. i want to diy the amp from
start to finish. i just need a few issues sorted out.
1 what is the bias voltage?
2 the schematic shows that 1 uf4007 is not applicable buh the pcb layouts show it is. may i know the one to follow.
3 can i use mbr20200ct diode in place of stps20sm100s?
4 what equivalent diode can i use in place of bas21 because in my country its not there.
5 of all the zener diodes on the schematic only 1n4744 is there in my country. i believe these are one watt editions. can i use 500mw
type for all coz these are here?
6 the 220 and 150 ohm presets are marked with 40%. am asking what it means
sorry for many questions i just want to be sure when making that am
fed with expert advice.
Old 24th October 2014, 08:35 AM   #2
You are attempting a very complex and dangerous project. It is workhorse's design so why not post in his thread where he shows it and ask him there?
The Class - H Amplifier
Ian
Old 24th October 2014, 01:36 PM   #3
240Vdc !
Ian is right to warn of the danger !!!!
regards Andrew T.
Old 25th October 2014, 07:32 AM   #4
i posted it earlier this week on his thread buh i have not gotten any response. am aware of thr dangers posed by this project buh am ready to do it. all i need is the few issues in post 1 to be sorted out.
Old 25th October 2014, 08:36 AM   #5
Again, it is Workhorse you should contact. PM if necessary.
Ian
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
