Mosfet in TO-3 package - diyAudio
Old 20th October 2014, 07:18 AM   #1
Vasquo is offline Vasquo  United States
Default Mosfet in TO-3 package
Is there a MOSFET part# (equivalent to IRFP240, IRFP9240) in TO-3 package?
Old 20th October 2014, 07:36 AM   #2
wrenchone's Avatar
The obvious answer would be the IRF240 and IRF9240 (the TO-3 parents of the IRFP TO-247 parts), but they'll be hard to find/quite possibly faked.
Old 20th October 2014, 11:06 AM   #3
tiefbassuebertr's Avatar
ask there:
Magnatec. ALFET Lateral MOSFETs
Old 20th October 2014, 11:41 AM   #4
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Sorry but no.
IRF(P)240/9240 are vertical/switching MosFet ; the Magnatecs are Lateral/audio types.
Very different, specially the biasing voltage.
Direct substitution will not work.
May I ask what does Vasquo need them for?
Maybe others can be used or the easy to find plastics fit there.
Old 20th October 2014, 11:59 AM   #5
Originally Posted by JMFahey View Post
Sorry but no.
This I know all. Therefore I write "ask there". This means, a call to this company clarify, whether there are replacements available or not for the IRF240/9240 in TO 3 outline.
Old 20th October 2014, 05:29 PM   #6
llwhtt is offline llwhtt  United States
Newark has IRF240s in stock now and IRF9240s due in December, Newark "should" be trustworthy.
Craig
Old 20th October 2014, 06:44 PM   #7
Sorry but no.
JM, this is for the amplifier schematic in the LME49830 datasheet.
Well, I'm a little surprise the TO-3 package is only 125W Pd vs (150Watt Pd on the TO-247 package), I thought the TO-3 package will have a higher Pd.
Old 20th October 2014, 07:47 PM   #8
wrenchone's Avatar
For a reasonable heat sink without fan or liquid augmentation, I would not allow more than about 30W dissipation per package. The 125/150W numbers are kinda bogus, as they assume a perfect heat sink and unacceptable temperature for the die inside the package. A TJ of 100C or so at max dissipation and max ambient temperature is a generally accepted limit for silicon devices.
Old 20th October 2014, 08:48 PM   #9
JMFahey's Avatar
Well, that datasheet clearly specifies IRFP parts, I'm baffled as to why you would want the TO3 ones , which by the way if ever existed are obsolete (so unobtanium/ultra expensive/etc.)
I thought you were repairing some old amp with heatsinks which only accept TO3 .
EDIT: as of dissipation, I am not surprised at all, TO3 is steel (worse conductor) while all of TO247 back is (tinned) pure copper.
Old 20th October 2014, 08:57 PM   #10
I just like the look of a TO-3 package. but yes, found some online and they're 4x cost as much. Looks like I'm back to the TO247 package.
EDA Package knutn Software Tools 6 22nd May 2014 04:35 PM
Mosfet colour dot on package alayn91 Solid State 3 5th May 2011 05:06 PM
46n15 250watt MOSFET in to220 package ! nigelwright7557 Solid State 10 18th March 2010 08:06 PM
transistor package anton Parts 8 11th August 2006 07:47 AM
Better transistor package? JojoD818 Solid State 41 18th July 2003 12:32 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
