cfp - variant --> current coupled - diyAudio
Old 11th October 2014, 12:19 PM   #1
Stee is offline Stee  Italy
Stee's Avatar
Default cfp - variant --> current coupled
as you know
the Sziklai pair also known as a "complementary feedback pair" (CFP)
have a resistor
http://www.epanorama.net/sff/Misc/Am...dback_Pair.pdf
my scheme drastically reduces the instability
Click on the diagram
Please download my best audio idea https://www.facebook.com/DiyAudioHiEnd
Old 11th October 2014, 01:18 PM   #2
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
That looks good. Does it have any affect on linearity -- distortion? And, also as a push-pull version?
-THx RNMarsh
Old 11th October 2014, 01:44 PM   #3
Assuming transistors Q2 and Q4 are identical (figure attached), Q2's current must be less than Q4's current. They have the same base voltage but Q2's emitter voltage is less than Q4's emitter voltage, due to the IR drop across R5. Thus Q2's base-to-emitter voltage is smaller than Q4's base-to-emitter voltage. Thus Q2's current is smaller than Q4's current.
Therefore "current booster" Q2, can only increase the total output current thru R6, by a factor of two at most - because Ic2 < Ie1. In my opinion, this nullifies one of the big advantages of the CFP, namely its enormous current gain (Iout / Iin). In a standard CFP the current gain is proportional to the square of Beta, while in this circuit the current gain is merely proportional to Beta. In fact it's less than 2 x Q1_Beta.
Old 11th October 2014, 08:20 PM   #4
Ketje is offline Ketje  Belgium
+1
And why is the OUT where it is drawn
Mona
Old 15th October 2014, 04:42 AM   #5
Stee's Avatar
Default in other words
The advantage is stability
current don't need to transform itself in voltage and again in current
to control the unit gain
Old 15th October 2014, 11:19 AM   #6
Stee's Avatar
Default also as a push-pull version
high speed
good for headphone amplifier
Old 15th October 2014, 03:04 PM   #7
DF96 is online now DF96  England
I would assume that Q2 is a power device and Q4 is similar to a driver device.
And there was I always thinking that stability problems were caused by unwanted parasitic feedback, rather than current-voltage transformations. If this version of CFP is more stable, then this arises from the reduced internal gain - which may have to made up elsewhere.
Roughly speaking, this is an emitter follower augmented by an asymetric current mirror. I am unclear what Q3 (in post 3) does - it will increase Miller effect in Q1.
Old 15th October 2014, 03:58 PM   #8
Stee's Avatar
Q3 (in post 3) cut RF on Q1
Old 15th October 2014, 04:05 PM   #9
How?
Old Today, 10:56 AM   #10
Stee's Avatar
Default because
work as a diode @0.6V
so cut half wave
see the application of this superdevice on VAS stage
Current noise between DC coupled op amps? miallen Analog Line Level 2 25th October 2012 03:45 AM
>> WTB: TDA1541A-S2 Taiwan made >> zeroalbedo Swap Meet 15 9th August 2012 04:34 PM
DC coupled Sand 'n Glass with Current Feedback ChocoHolic Tubes / Valves 35 31st March 2012 11:16 AM
Current mode and coupled output inductor? eem2am Power Supplies 13 21st September 2011 08:18 PM
> Audio <> music <> quick <> synergy <> angst>? rick57 Everything Else 0 4th May 2007 04:03 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
