Looking for the Über Buffer - diyAudio
Old 8th October 2014, 10:05 PM   #1
Default Looking for the Über Buffer
Well guys,
I'm looking for an audio signal buffer that can output 2v pp into a 100R load. The reason? It's the inverting input node of my amp schematic; it's run in inverting modus. The reason for this is partially the elimination of the CM voltage, but primarily to control sources and returns in order to get the global grounding right and have zero 'dirty' returns. In a simulation I verified that the chosen grounding topology does not distort the speaker output.
In order to make this work, I need to buffer the inverting input of the amp, so this buffer will be the source going through the feedback network, rather than the signal drive coming from the preamp board. The non-inverting input is already high-impedance and doesn't need to be buffered. Instead it is connected to the DC servo sense, which also needs to be grounded. These two connections go off-board through a wire to the global star point.
This way, the output signal of the preamp will be relative to the star ground; the input of the poweramp will also be references to that same starground ( and NOT the ground of the board itself!). The fun bit is, that because of the inverting modus, the virtual ground created should exactly be at the starpoint potential. This means, that the Rfb connects the starpoint potential to the output node, which means immunity to dirty currents from various sources. This setup gets me a groundloop free config while still be able to use two power amps on a shared supply and preamp.
With a test rig I was able to simulate that the grounding scheme did not increase THD, eventough I had given resistances to all the various supply power leads and so on.
But! Back to the beginning. To make this grounding scheme work as designed, the power amp must have a capable, distortion free buffer that can drive 100R with like 0.00morezeroes% low THD
It would be a shame if my prototype's supposed specs were squandered by a lousy grounding scheme and or sub optimal buffers.
So... what'd you guys recommend me to use as a unitygain buffer that can drive 2Vpp into 100R at amazingly low distortions?
Negative Feedback: The Need for Speed
Old 8th October 2014, 10:16 PM   #2
Use four 5532 amplifiers (two DIP packages) in parallel, each configured as a buffer and with 1R series output. A single 5532 amplifier can drive 600R to much higher voltages at about 0.0005% distortion, rising only above 10kHz to about 0.001%. That should be a sufficient number of zeros... You mush drive the quartet lot with a low source impedance, e.g. below 1k ohm.
"Hardware eventually fails. Software eventually works" - Michael Hartung
Old 9th October 2014, 02:06 AM   #3
Maybe Kean's? The Kuartlotron
Old 9th October 2014, 05:50 AM   #4
I've tried to do this with 4x LT1115 (LT's 5532-like opamp), . They don't alter THD when one is loaded by 10K. However, using 4 of them, each driving up to 2.5mA 2Vpp still leaves a lot to be desired at 20KHz
Old 9th October 2014, 06:03 AM   #5
BV is offline BV  Slovakia
LM6171
Diamond Buffer - Super Buffer peranders Solid State 34 16th May 2010 02:46 PM
buffer TUBESMAN Solid State 4 22nd October 2008 06:32 PM
FREE and ÜBER HIFI [Nine Inch Nails - The Slip] ak_47_boy Music 7 22nd May 2008 04:10 AM
Opamp + buffer, how to bypass buffer at HF for unity gain? Christer Solid State 10 29th October 2003 07:50 AM
A Buffer ? Why ? Elkaid Chip Amps 29 15th September 2003 01:40 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
