Lite mv 02 remote HELP - diyAudio
Old 7th October 2014, 11:17 PM   #1
Default Lite mv 02 remote HELP
Hi Folks
I have an amplifier that has been built for me using the lite remote volume control,, alps potentiometer. The remote set has failed I think, so I have bought a universal remote control to try and work it. However I can not find a code for the "Lite" remote set. Can any one let me know what this could be?
Thanks in advance if any one can help
Old 8th October 2014, 03:17 AM   #2
This appears to be a Chinese kit of assembled modules from many Ebay or Aliexpress stores:
HiFi Audio parts Sotre>>Amplifier kit > Tube Preamp > DAC kit >>shipping to worldwide
If the problem is actually failure of the handset, it would seem unlikely that the code firmware is lost and the unit should be repairable, if not a battery type or fitting problem. A local repair shop should be able to verify that the remote is emitting IR at least. If so, the problem is in the amplifier's sensor operation or control circuitry. I would have the constructor check that over first.
To use a universal remote, it would need to read and copy the unknown code from the handset. I can't imagine that the kit supplier has any idea what code is used or how to reprogram the handset so that may not be helpful. Otherwise, the cheapest option will likely be a complete replacement set, as originally fitted, or similar.
Ian
Lite Audio MV-01 / MV-06 remote controlled volume/input selector roffe Parts 82 16th March 2016 03:23 PM
MV-06 Motorized remote control volume and source selector reactivepower Swap Meet 2 17th November 2012 05:51 PM
lite audio mv-02 4 way remote control sb****33 Everything Else 0 27th February 2012 01:46 PM
USAmps 50x REV 02 remote turn on blown Cr@sh Car Audio 4 13th June 2011 05:17 PM
LiteAudio MV-01 motorize remote volume control jeffshort2000 Swap Meet 5 28th October 2009 08:06 PM
Copyright 1999-2017 diyAudio
