need contact adresses of this HUGE amplifier - Page 2 - diyAudio
Old 28th April 2011, 07:50 AM   #11
plz anyone upload circuit schematic of FIDEK FPA G12
Old 28th April 2011, 08:04 AM   #12
this amp is service manual some parts list is fake
Old 30th April 2011, 04:03 AM   #13
Plz anyone send correct schematic of fidek g12
Old 30th April 2011, 08:22 AM   #14
wahab is offline wahab  Algeria
Good schematic, but there s a few misdesigns...
The worse is the use of a MJE340/350 pair as common emitters
part in the cascoded VAS..
It make sense as common base part for the cascodes, although
there s far better devices that suit this purpose.
Also, they use a heavy shunt compensation resulting in a low
slew rate of 40V/uS wich is not really enough for such high
level output...
They use 120V 2SA970/2SC2240 as common base part in the
input differential, and althoug it s enough since they see only 72V
EC voltage in normal functionning, they can t sustain the 144V
rail voltage, wich is not cautious since at power on, there can
be quite different conditions than when voltage have settled...
Other than that, construction is serious...
Old 30th April 2011, 10:34 AM   #15
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
This is a PA amp. OK for disco. Built like tank.
Having said that, my amp is rated at 280W per channel and does around 500W into 4 Ohms and it weighs 38Kg . . .
bonsai
Amplifier Design and Construction for MUSIC! http://hifisonix.com/
I have found a special amplifier, am trying to contact the designer destroyer X Solid State 224 11th June 2012 02:31 PM
Trying to contact X - PRO homertooties Forum Problems 0 20th January 2009 10:06 AM
trying to contact col Vinnie2 Forum Problems 0 23rd December 2008 11:31 AM
Copyright 1999-2017 diyAudio
