ESP Project 3A - diyAudio
Old 29th September 2014, 07:20 PM   #1
Default ESP Project 3A
Hello Guys.
I'm new at diyAudio and I'm starting my first DIY amp.
It will be an ESP Project 3A.
So, I'm shopping around for a transformer and capacitors.
So far I have as a transformer :
HAMMOND
TRANSFORMER, TOROID, 60V, 500VA
and as a capacitor:
UNITED CHEMI-CON ESMH101VSN472MR50T CAPACITOR ALUM ELEC 4700UF 100V 20%, SNAP-IN
any other recommendations?
Old 29th September 2014, 07:32 PM   #2
100V capacitor is wasting too much money on a voltage rating for the P3a that will run from supplies @ +-30Vdc to +-50Vdc.
Use 50V or 63V capacitors which are far cheaper.
regards Andrew T.
Old 29th September 2014, 07:36 PM   #3
PJN is offline PJN  United States
Make sure that you know what rail voltages that amp calls for. 60vac will yield ~ 82 vdc after rectification, sounds a bit high for that amp.
Old 29th September 2014, 07:42 PM   #4
Hello PJN, the transformer is 2 x 30V ...
Old 29th September 2014, 07:44 PM   #5
Thanks for the reply.
If the diference in price is only 1 dollar less if get a 63V .. would you get the 63v or 100V?
Old 29th September 2014, 08:11 PM   #6
still4given's Avatar
You didn't follow the link. It is a 30-0-30vac transformer. Should be about right for that amp. It's a bit pricy though. He can get an Antek for half that.
http://www.antekinc.com/an-5430-500va-30v-transformer/
X-BoSoZ, B1 Mezmerize, P101, Symasym, KSA 50, Aleph-X, Leach Low TIM, Leach Superamp, Dx MKIII, Super A, Honey Badger, JLH 1969, Gainclone. FetZilla, Peeceebee, VSSA PMI & jkuetemann, SKA GB150, Ovation nx & sx, AX&SX-14, TMG8, Slewmanster w/CFA-XH, Wolverine, Spooky, Symasui, Low TIM hybrid
Old 29th September 2014, 08:23 PM   #7
Thanks guys for the quick comments.
another question :
you guys think I should have what capacitance per amplifier?
Rod recommends no more than 10000uf per amp..
I was thinking in use about 18800uf .. like 4 x 4700uf per amp.
Old 29th September 2014, 09:13 PM   #8
For your first amp, you could do a lot worse than listen to Rod Elliot. He has been around the block at least once.
Old 29th September 2014, 09:28 PM   #9
You're right, I didn't follow the link, I stand corrected.
Old 30th September 2014, 09:50 AM   #10
another question :
I recommend that a full range amplifier has it's F-3dB set to around 1Hz to 2Hz.
That requires the smoothing capacitance to be around +-20mF (20000uF) for each amplifier.
Your 4 off 4700uF, (=+-19mF per amplifier) on every supply rail fits that recommendation. That's 16 caps for a stereo amplifier. That will also give you very high ripple current capability and thus increase the life of these electrolytics.
regards Andrew T.
ESP Project 3A Parts List? Bakewell Parts 1 9th November 2010 10:55 AM
ESP Project 3A - 60-100W Hi-Fi Amplifier Problem and need helps bugbite2k Solid State 18 31st December 2004 01:18 PM
A new ESP 3A amplifier! Duo Solid State 7 14th April 2003 02:59 PM
ESP project 3a PCB foil patterns FullThrottleRic Solid State 5 13th August 2002 10:00 PM
ESP project 3A amp at +/-50V Freddie Solid State 6 6th January 2002 02:54 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
