Yamaha DSP-E800 External Decoder Subwoofer Gain - diyAudio
Old 24th September 2014, 03:46 PM   #1
Default Yamaha DSP-E800 External Decoder Subwoofer Gain
Non-electronics expert needs some advice.
I own a Yamaha DSP-E800, and am very happy with it. However, it has a problem in the fact it has no gain compensation for the -10db LFE channel level when used with itís 6-Channel direct analog inputs and an external decoder Ė the decoder in question being a Panasonic DMP-BDT500 Blu-ray player.
Anyway, I think I may have a simple solution to the problem by using a cermet preset which could be adjusted to limit the level of the Yamahaís internal decoderís subwoofer output to a level closer matching the 6-Channel sub input - prior to the input switching between the internal and external decoders and the E800ís main output level control. The problem being Iím not sure what the finer points of the electronics might be Ė impedance matching, noise, etc.
The part of the circuit Iím looking at is on the INPUT (1) board here:
The cermet would be inserted between the junction of R452 (47k) / C431 (10uf/25v), the E line (ground), and the wiper to pin 26 of IC402 (LC78213 Analog Function Switch).
Itís somewhat fortunate that thereís a convenient removable short wire link (J453, if you have the service manual) on the circuit board linking that particular cap/resistor junction and pin 26 on IC402, and also allows an easy connection to ground Ė so the problem of mounting a cermet preset on the board shouldnít be too much of a problem.
So the questions would be: does anybody see any major problems with the idea, what value cermet would be most appropriate given the drop in gain required Ė or, more importantly, is there a better way to accomplish the same thing?
Thanks for any help offered.
Faulty Yamaha DSP-A2070 RishiGuru Solid State 6 2nd June 2012 07:03 AM
External DSP Delay oublie Digital Line Level 2 3rd November 2010 11:37 PM
Yamaha DSP-E390 schematic Juergen Knoop Solid State 0 17th March 2007 02:56 AM
Is external DSP needed for CS4258? Wynand Digital Source 10 20th July 2006 08:30 AM
YAMAHA DSP-A2 Schematic palesha Solid State 7 23rd December 2005 05:09 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright ©1999-2016 diyAudio
