Unusual buzzing situation - diyAudio
Old 22nd September 2014, 04:08 PM   #1
mazur is offline mazur  United States
Default Unusual buzzing situation
Hi.
I have a Soundcraftsmen A100 Pro amplifier. MOSFET outputs and input volume control. I have an audible buzz coming through the speakers as follows:
- with no input connected, buzz is gone when volume is all the way down and increases steadily and stays there with the volume all the way up.
- with an input connected, buzz is gone when volume is all the way down, then increases as volume is turned up, then it disappears when it's all the way up.
Same thing for both channels. Completely re-capped and pots cleaned. Ground is floating (not connected to the case). Couldn't find any ground loop.
It sounds very nice and with the volume all the way up it's dead quiet. I would like to use the volume control since this is driving my horns on a bi-amped system.
Any ideas?
Elias
Old 22nd September 2014, 04:19 PM   #2
tiefbassuebertr's Avatar
Originally Posted by mazur View Post
Hi.
Any ideas?
Elias
Is it this model?
Sweet Soundcraftsmen Score
Where is the case (chassis) connected ?
It must be connected with GND at least about a resistor and/or (parallel switched) cap (go to this example at Mission Cyrus integrated amp
http://img84.imageshack.us/img84/8545/img7505b.jpg
here it is R121 near the volume control shaft at bottom, right site.
In case of bown resistor one have the same situation as you mentioned at post #1.
Old 22nd September 2014, 05:07 PM   #3
Originally Posted by tiefbassuebertr View Post
Is it this model?
Yes, it's the same model, but with volume control.
The ground is not connected to the chassis. It's floating. There is a common ground in the board that holds all capacitors. The volume pots are connected to the ground point. There are no additional resistors from the pot. When all the way down, it grounds the input signal. When all the way up it provides a 50k input resistor to ground and a direct path for the signal to the input cap.
Elias
Elias
Old 22nd September 2014, 06:55 PM   #4
Elias
This is the reason for the unwanted buzzing noise. Connect the chassis to the GND connector of the volume control or the input female connectors and observe, what happens in the max. position without input signal and without connected preamplifier resp. source device (i. e. open input plugs).
Hybrid situation GeneZ Solid State 2 2nd July 2011 12:45 AM
help plsssss...............1 more situation i have here victorioarvin Subwoofers 0 20th July 2008 02:04 PM
best of a bad situation bobtrancho Multi-Way 10 22nd August 2007 08:29 PM
More situation description jlg4104 Tubes / Valves 1 2nd December 2002 03:13 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
